losi tool sizes.. SAE, metric?
reason i ask, i have both.. mix matched, and well, its confusing.
the 2 main sizes i use, 3/32, and 5/64. but, am i supposed to use metric? i think 2mm is 5/64, or maybe its 3/32. i dunno. i have a 8T 2.0, and i want to find a set that is specific to my truck. not carrying around 12 drivers, and never knowing if its going to fit or not. the confusing is the brake cam linkages. sometimes .05, and sometimes 1/16 i think.. so is the .05 metric, and the 1/16 american? |
.050, 1/16, 5/64, 3/32. Everything on the vehicle.
i pulled this out of the manual...
http://i51.tinypic.com/104eo3n.jpg is it saying, those 4 sizes are hex drivers required for the kit, or those are the required nut drivers needed? i need to know hex drivers most importantly. |
Originally Posted by builtb16a
(Post 8261085)
if your saying 5.5 and 7... what the hell are those 4 odd ball sizes for?
Everything on a losi is sae. The .05 you ask about is .050". Fifty thousandths of an inch. Only thing metric will be on the engine, not the vehicle.
I don't know if Losi is metric or fractional.
but........................1mm = almost exactly 0.040" 1/16" = 0.0625" ...close to 1.5mm 5/64" = 0.0781" ...close to 2.0mm 3/32" = 0.0937" ...a loose 2.5mm 1/8" = 0.125" ...a tight 3.0mm Geez. 5 replies while I was typing.......... |
Originally Posted by hambone
(Post 8261084)
Yep that's all you need. Ball link on carb is metric, clutchbell retaining screw is 2mm hex. Can't remember ball link size.
(Post 8261130)
the clutch bell is my 5/64th. so, 5 really. those 4 SAE's.. and the 1.5mm. |
(Post 8261142)
ball link must be the 1.5mm. its the red handle, the only odd ball.. so thats the mix up.
Yeah get the 4 SAEs, 2mm and 1.5mm. I think the shock nuts and camber link nuts will need a 1/4 in nut driver. A small open end wrench works better for the camber links.
(Post 8261147)
Actually the cluthbell is 2mm. Slightly bigger than 5/64. You can use 5/64 but it'll strip.
(Post 8261094)
Originally Posted by shanem121
(Post 8261091)
Nut drivers are optional. But they are 5.5mm and 7.0mm i am pretty sure.
nope....11/32 and 1/4
(Post 8261147)
Originally Posted by dnebout
(Post 8261158)
this is what you want for the camber links. ;) http://www.amainhobbies.com/product_...-Wrench-35-5mm |
