Durango DNX408 - Fast enough to win the World Title. >
Old 01-03-2011, 04:21 PM
  #1291
Any of the Leisure hours boys got steps for the buggy indoors yet? tryin to get mine ready for when i can race there. Thanks DW
losi8ight2.0 is offline
Old 01-03-2011, 04:31 PM
  #1292
apex-racing's Avatar
Originally Posted by rc ace
thanks durango and great job building the nicest car out there
I CONCOUR! can't wait for a V2 from all the input and OFCOURSE the TRUGGY!!!
apex-racing is offline
Old 01-03-2011, 04:44 PM
  #1293
rc ace's Avatar
I second that can't wait for the TRUGGY i feel weird just running buggy gotta have both!!
rc ace is offline
Old 01-03-2011, 05:37 PM
  #1294
The Centered, low CG design could be wicked in Truggy? Where can we pre-order?
What droop settings is everyone starting iut with?
SPEEDSKI is offline
Old 01-03-2011, 05:45 PM
  #1295
Default ATT: Team Durango
so i working on my dnx408 and the lower servo saver arm is cracked again.... (sec time) please address. and yea the center diff is still leaking like a sive. but going threw everything else and.... Money. would like to see a rx box that you can take the battery out without disturbing the antenna and s/w its a pain when your in a rush with all that wiring. going to try 4-7-7 on my diffs and 40wt in the shocks. would like more rear traction on power coming out of corners had 5-10-15 and 600cst in the shocks....
Old 01-03-2011, 06:11 PM
  #1296
Frank L's Avatar
Trader Rating: 148 (100%+)
Another thing you could try for more rear traction is moving the rear hub forward and making the wheelbase shorter. You will lose a little bit of steering but this car has tons of steering, but you will gain rear traction.
Frank L is offline
Old 01-03-2011, 06:34 PM
  #1297
right on and how do i do that with the spacers?
Old 01-03-2011, 07:28 PM
  #1298
rc ace's Avatar
yeah just put them behind the hubs so it pushes them forward
rc ace is offline
Old 01-03-2011, 07:32 PM
  #1299
Frank L's Avatar
Frank L is offline
Old 01-03-2011, 07:39 PM
  #1300
pointforward's Avatar
Originally Posted by Bernarossi
Found this video of someone showing the linkage at work. Does he have his setup wrong?
+ YouTube Video
- Yeah, the swivel for the brake link on the servo horn is upside down
- the hinge for the linkages to the brake/throttle looks set maybe 15 degrees too far counterclockwise.
- the EPA on his throttle servo is set too far on the throttle side
- the silicone hose bushing and washer is set too far from the swivel, which ill give some lag on the brake side, unless he wants that lag
- the on/off switch is set so that on is forward of the car. better to have "on" towards the rear, so that if the car impacts on anything (which usually happens moving forward), and the switch catches, the electronics won't get turned off.
Also helps to put a small spring (like the spare one for the brake) on the other side of the throttle swivel (opposite the long spring) to help it go back to neutral. A bit of a fail-safe.
pointforward is offline
Old 01-03-2011, 07:49 PM
  #1301
jbright33's Avatar
Trader Rating: 15 (100%+)
[QUOTE=pointforward;8431541]-- the on/off switch is set so that on is forward of the car. better to have "on" towards the rear, so that if the car impacts on anything (which usually happens moving forward), and the switch catches, the electronics won't get turned off.
you should run a switch with on facing foward. think of a car crash when someone hits something head on do they fly out the back window or the front. same thing with a switch. dont mean to hijack a thread or anything I have just been doing alot of reading up on the durango.
jbright33 is offline
Old 01-03-2011, 08:34 PM
  #1302
rc ace's Avatar
the on off switch should face forward so when you crash nose first it does'nt turn off
rc ace is offline
Old 01-03-2011, 08:40 PM
  #1303
Frank L's Avatar
Why the hell would anyone run a switch. Just one more thing to fail. Mini deans here.
Frank L is offline
Old 01-03-2011, 08:56 PM
  #1304
Bernarossi's Avatar
@FrankL You run the mini deans outside the box? I haven't built my durango yet. Going to start this week. Can't wait. That is why I was looking at that video to see how that the link works.
Bernarossi is offline
Old 01-03-2011, 09:22 PM
  #1305
man i like having a switch never had a problem before! and it keeps things clean......
