Durango DNX408 - Fast enough to win the World Title. >
Old 01-01-2011, 09:23 AM
  #1186
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by nitrozilla
i think unless he was in a head on collision it prob wasnt a buggy. did you leave your buggy unattended at all at the track??
Many many people picked up my buggy that day on the bench. Most of them I know but there were a lot of hands on it. I don't think someone sabotaged it.
Originally Posted by infanterene
That piece is hollow(lightweight). It can break but it probably wouldn't cause a dnf.
No dnf I finished 4th or 5th. The diff was still snug where it should be.
Originally Posted by javijp
Which is better 5000 or 7000 in the rear differential? before I 15000 and in the central 7000.
The black-Losi spring equivalent of durango?
I would try 7-7-5. I started with 15-10-5 Nd the front pulled too hard which left the back very loose. The Losi blk springs measure the sime diameter on the wire as the stock blue durango springs. I liked the Losi green springs best. I tried silver green and black.
I would also add that I took the diffs apart yesterday center and rear and it was very very easy. Take the engine out and then 4 screws on the top and the center diff comes right out. Take the front cover off and the front diff slides right out. Very very simple. I like it.
Frank L is offline
Old 01-01-2011, 09:33 AM
  #1187
MindThoughts's Avatar
Trader Rating: 19 (100%+)
Default Durango DNX408 You Tube Video Link.
Very nice run. Thank you for posting this link.
PS. Direct link to video/website.
http://pitlinerc.com/
Note: I'm looking forward to seeing the 100% purpose designed and built for electric- Durango DEX408- said to hopefully be out by March of this year
Video of Robert Batlle testing Team Duramgo
pitlinerc.com
MindThoughts is offline
Old 01-01-2011, 10:15 AM
  #1188
apex-racing's Avatar
Originally Posted by mcion
Damn, How do you crack a diff case if you have a bumper on and the shock protrudes out further than that portion? Now I am pretty sure the plastic is not Xray like, which is what I was really curious about.
is the weather cold were your at? i would hate to see the other car
apex-racing is offline
Old 01-01-2011, 10:25 AM
  #1189
The Losi black springs are softer than the blue durango.
I've proven with the setup of geometries series.
In the oil shocks 300 Losi, blue springs, and also provide black Losi springs.
with 10.000/5000/3000.
What do you think the setup?
bell 13 or 14?
javijp is offline
Old 01-01-2011, 11:02 AM
  #1190
Frank L's Avatar
bell 13 or 14?
Depends on the track and the engine. Big track and go with the 14, small track and go with the 13. Your engine needs to have enough bottom too to push a 14 tooth. Some do and some dont.
Frank L is offline
Old 01-01-2011, 11:07 AM
  #1191
Does anyone have a losi to durango spring wt comparison?
AndyF is offline
Old 01-01-2011, 11:10 AM
  #1192
Marcus Falconie's Avatar
pitlinerc.com
high idle
Marcus Falconie is offline
Old 01-01-2011, 11:22 AM
  #1193
JQ
Its a novarossi....
JQ is offline
Old 01-01-2011, 11:24 AM
  #1194
Alan D. is offline
Old 01-01-2011, 12:18 PM
  #1195
Bernarossi's Avatar
How does the 0 or 1 degree rear hub carriers affect the cars performance?
Bernarossi is offline
Old 01-01-2011, 01:01 PM
  #1196
Yes a Novarossi
javijp is offline
Old 01-01-2011, 01:54 PM
  #1197
I think, if you are running the 2/3 bushings with 0 degree rear hubs you'll have 3 degrees of toe in. If you run the 1 degree rear hubs I believe it will give you 4 degrees of toe in......although I haven't measures it and could be wrong...
Jaf1977 is offline
Old 01-01-2011, 03:50 PM
  #1198
where can i find a good/cheap life pack that will fit in the dnx408? Does hobbyking have one?
buggy_driver is offline
Old 01-01-2011, 04:34 PM
  #1199
I have ordered this intellect that is cheap and very good quality for the value!!
http://cgi.ebay.it/ws/eBayISAPI.dll?...#ht_1424wt_907
mazzinga is offline
Old 01-01-2011, 05:44 PM
  #1200
DRCRacer299's Avatar
At the moment the car has 3* of inboard toe. If you use the 0 rear hub you retain that 3* of rear toe. If you use the 1 degree on the normal way you will have 4* of rear toe. If you swap sides on the rear hubs is makes it +1 and you will have 2* of rear toe!
Hope that helps.
DRCRacer299 is offline
