Durango DNX408 - Fast enough to win the World Title. >
Old 12-31-2010, 09:45 AM
  #1126
captain america's Avatar
Originally Posted by pointforward
The grommets attach to the 340016 parts which in turn attach to the metal plate, so upon installation, you're correct to say that the metal plate does not touch the servo. BUT, i think that might not be the case once the car starts bouncing around. the fact that you've left a millimeter of space between the servo and the plate means that you've left a millimeter that the servo and plate can travel and come together.
If you look at the manual, you'll see that there's no way for the servo plate to move because it's firmly keyed into and anchored to the chassis. As was proposed earlier, it wouldn't hurt to put a sheet of foam rubber between the servo tray and the servo itself, as this will greatly help dampen vibration and ensure that the servo continues to perform as needed. Also, some heat insulation tape on the bottom of the servo (the side that faces the engine block) is something I'd recommend. I'd gladly test this myself, but Quebec won't get any remotely hospitable temperatures for another 3 months
captain america is offline
Old 12-31-2010, 09:46 AM
  #1127
Originally Posted by infanterene
The servo does touch, at least mine did. Last night I took my steering servo out and noticed it has been rubbing on the bottom. All the anodizing has worn off from the case.
I have since put servo tape under it and all should be well. I strongly suggest servo take under the servos on this car. Its an easy fix.
Did you use the little plastic pads to raise the servo when you installed it?
Old 12-31-2010, 10:41 AM
  #1128
Frank L's Avatar
Trader Rating: 148 (100%+)
I just inspected the clutch and changed the springs. The mugen springs and shoes are the same as the durango. I installed 1 - .9 mugen spring to smooth the clutch out a little bit.
No pads here there was plenty of clearance. Just rubber garments on the servo itself. I think a piece of servo tape would make it worse because while it may dampen the vibration it will also cause the servo to touch which in time will cause it to fail.
Frank L is offline
Old 12-31-2010, 10:57 AM
  #1129
Trader Rating: 18 (100%+)
No because it looked like I had 1.5mm clearance. I also noticed that with the pads the servo wasn't located as securely as I'd like.
infanterene is offline
Old 12-31-2010, 11:12 AM
  #1130
Integra's Avatar
I always wondered where you were out of Captain. Does Quebec compete in the RCpro series ?
Might see you at the Finals this year if your the traveling type.
Integra is offline
Old 12-31-2010, 11:20 AM
  #1131
kaptain crash's Avatar
Trader Rating: 46 (100%+)
I know there is a bunch of guys from canada that do motorma.... great bunch of guys.
kaptain crash is offline
Old 12-31-2010, 11:34 AM
  #1132
Frank....did you use new servos on your build or pull them out of the L buggy?
If you are as hard on this buggy as you are on your self boo boo you will put them to the ...REAL .....test.
Old 12-31-2010, 11:41 AM
  #1133
Frank L's Avatar
The rsx servos had 1 run on them in the Losi. And yes I will definatly put them to the test. If they are good then I will have no issues. If not then you will find them for sale but the rsx servos are the smoothest servos I have ever seen and they are extremely quiet too. But if they junk out I will throw some Savox hv's in. So far them seem to be good but the rsx's only have 2 race days on them. Feb at the nitro challenge will put them to the test.
Frank L is offline
Old 12-31-2010, 11:54 AM
  #1134
One last question...is a lipo pack a must in this buggy ?
Old 12-31-2010, 12:03 PM
  #1135
No just have the charging lead from the switch dangle out from the radio box with the other wires.
If your running long finals then maybe a large lipo would help but it's not that hard to change the battery.
Of note last weekend there was standing water and a sodden astro track, yet the receiver box was completely dry, though the battery compartment had a little water in.
AndyF is offline
Old 12-31-2010, 12:13 PM
  #1136
thanks.....couldent tell by the pictures how much room there was for the battery.
Old 12-31-2010, 12:16 PM
  #1137
No idea about RC Pro cos I don't race. Where are the finals gonna be held?
Old 12-31-2010, 12:19 PM
  #1138
A bead of silicone around the base of the plate where the plastic housing meets should take care of any water infiltration
Old 12-31-2010, 12:21 PM
  #1139
Integra's Avatar
You dont race ? why not ?
Finals location will be posted Any day now in the Canadian Section, Steve aka svengali will be making a thread for it and other RCpro Canada stuff.
Integra is offline
Old 12-31-2010, 12:24 PM
  #1140
Im wounder if your the guy at motorma that was at the canada table that was close to me in the pits...you where like the ...team dad...or boss, if so I injoyed our chat.
