Durango DNX408 - Fast enough to win the World Title. >
Old 05-26-2013, 05:30 PM
  #9421
Suspended
Originally Posted by av4625
No as you will notice i wrote DEX408v2 not DNX408v2, im a durango driver and know all about the DNX lol but as far as i no there is no v2 for the DEX
Yeah and you asked a question about the wrong car, in the wrong area of the forum. Based on how unintelligible your posts usually are, I figured you might actually have never heard of the DNX408v2. When I read your post, I was concentrating on the "never heard of the v2" part, not the one time you mentioned DEX. I only made my mistake because you made 2 of your own.
On a more thread appropriate note, I have been working on a new brake linkage system. I just need to get a couple more parts, and I'll post up some pictures.
ifuonlyknew is offline
Old 05-26-2013, 05:57 PM
  #9422
R/C Tech Elite Member
RevoRacer50's Avatar
Trader Rating: 41 (100%+)
I'm doing the same as we speak with the servo standing up but moved in I will post pics as well.
RevoRacer50 is offline
Old 05-26-2013, 06:53 PM
  #9423
Fatam's Avatar
How do you get a return spring on your carb. The throttle linkage won't return the carb and I put a spring from the high speed needle to the slide and it catches. Any thoughts? Anyone else have problem with the linkage?
Fatam is offline
Old 05-26-2013, 07:39 PM
  #9424
Maybe this will help. But it sounds like a binding issue in the carb or the linkage. But I am yet to ever have a problem on the linkage.
http://www.team-durango.com/in-the-p...rticle_id=2100
Old 05-26-2013, 08:42 PM
  #9425
I've never had much luck with return springs. They always pull at an angle, causing the slider to wear unevenly, and / or create binding issues. In a few cases where i felt i needed it, i've been using a few good rubberbands, or similar. But due to the heat, they don't last forever.
B!
Mr B is offline
Old 05-26-2013, 11:11 PM
  #9426
I have mine on the bell crank...works well there. Only drawback is if the linkage pops off it won't help then but works just fine for a power failure.
InspGadgt is offline
Old 05-26-2013, 11:40 PM
  #9427
Dino_D's Avatar
Originally Posted by stg099
Thanks for the heads up. I tried the stock wheels first and they in fact were ok, but most of my tires are on AKA wheels, which rubbed. I just dremeled off the outer holes for now, if the new hubs represent a big improvement I'll just grab a fresh set of rear arms.
On another note, I'm really really happy with how the car is handling/performing now that I found a neutral setup that I like. The only issue I'm having consistently is killing shock bladders. It appears that the piston has too much "up" travel and is Guillotining the bladders at the upper egde of the shock body. Has anyone found a way around this other than putting spacers on the shaft to limit up travel?
First of all make sure the top of the shock, where the bladder sits on top treads dont have any sharp edges. Sometimes from the manufacturer its not as smooth and it will rip, regardless of bladder. If that doesn't work, try Losi bladders.
Dino_D is offline
Old 05-27-2013, 05:46 AM
  #9428
your so ignorant and all your posts are and im not the person to bring up the DEX in this thread i asked a guy a question that had mentioned it and my posts arent "unintelligible" im giving better set up advice than you are. i didnt make any mistakes in my post!!!!
av4625 is offline
Old 05-27-2013, 05:48 AM
  #9429
i run losi bladders with about 5mm of fuel tubing on the shock shaft to stop the up travel a little!
av4625 is offline
Old 05-27-2013, 06:17 AM
  #9430
Tyson72's Avatar
+1
Tyson72 is offline
Old 05-27-2013, 06:18 AM
  #9431
Tyson72's Avatar
So no one is really sure about wen Lutz prototype will come out as kit?
Tyson72 is offline
Old 05-27-2013, 12:18 PM
  #9432
No, lutz said at silver state that some parts would be comin into production soon but i cant see it as a UK team driver that has one said that it wouldnt be production ready for neo 13 so im guessing it will be ready for next year, well i hope it is as i will have two years on my current car by then, it is goin really well atm as i replaced the chassis and bulkheads and a few other things!
av4625 is offline
Old 05-27-2013, 01:34 PM
  #9433
It's not the pistons cutting the bladders it is the shock body...the stock bladders are not very good...switch to the Losi ones and you won't have any problems.
Old 05-27-2013, 05:56 PM
  #9434
Trader Rating: 50 (100%+)
Great tip, I have run Losi bladders for a while, and filed down the edges of the shock bodies, but would still cut bladders really often. The fuel tubing is a great idea. Thanks.
stg099 is offline
Old 05-28-2013, 06:31 AM
  #9435
its the piston comin up and hitting the bladder as i always used to break the bladder and if u were running vented caps the oil went everywere but i run losi bladers an the fuel tubing with no problems
av4625 is offline
