Durango DNX408 - Fast enough to win the World Title. >
Old 03-15-2013, 02:04 PM
  #9226
CDCRacing's Avatar
Question: are the 408 rear shocks the same! I'm getting the same part numbers for rear springs from Buggy to truggy. The Durango site has me confused any help would be great! Thanks in advance
Scott
CDCRacing is offline
Old 03-15-2013, 02:40 PM
  #9227
Trader Rating: 14 (100%+)
Yep...the rear shocks are the same.
rpmhobbies is offline
Old 03-15-2013, 04:58 PM
  #9228
CDCRacing's Avatar
Thank you sir!
Old 03-17-2013, 08:35 PM
  #9229
So does moving the receiver battery more forward to the front of the car better anything or create an improved set up? or is it kind of an ocd type of decision?
sn47som1 is offline
Old 03-17-2013, 08:45 PM
  #9230
Moving the battery has a bit to do with your preferred setup, and center of gravity.
B!
Mr B is offline
Old 03-17-2013, 10:57 PM
  #9231
Hey guys, how many tanks really need to be run through a new motor from the start, before really leaning down on it for a good race tune?
sn47som1 is offline
Old 03-18-2013, 04:56 AM
  #9232
DBL15's Avatar
Thumbs up
I ran 8 tanks up and down the street on a new .19 OS speed before the weekends events and it worked a treat and was getting over 9mins and I know it's a tad rich still.
DBL15 is offline
Old 03-18-2013, 03:05 PM
  #9233
Cool, great info, I have 10 tanks through mine and was recommended to run another half a gallon before really starting to lean it out. This seems excessive to me, but I want to get 10+ gallons from this modded motor. What do you guys think?
sn47som1 is offline
Old 03-18-2013, 03:07 PM
  #9234
tobamiester's Avatar
Trader Rating: 359 (100%+)
What brand/model motor ?
tobamiester is offline
Old 03-18-2013, 03:36 PM
  #9235
R/C Tech Elite Member
RevoRacer50's Avatar
Trader Rating: 41 (100%+)
10+ gallons?? I sure hope its an O.S but 10 gallons on a full blown race tune will be hard with out a pinch.
RevoRacer50 is offline
Old 03-18-2013, 09:37 PM
  #9236
Ya I hear ya its certainly a stretch, but I'm hearing of racers getting that kind of longevity out of their Radicals.
On to a more serious not- I NEED A SUSPENSION GURU HERE. The more I have been doing my homework the more I have been learning on suspension mechanics and tuning. My problem is I have tried multiple different rear shock tower inner mounting locations for the rear camber link. Just when I get the right camber degree set on the wheel and a good mounting location, I always get positive camber gain at the suspension's full rebound stroke If I switch up mounting locations on the tower to decrease the positive camber gain at full rebound (my droop setting basically), the camber starts to creep past zero into positive land during chassis roll. I want to only have an increase in positive camber to reach zero under chassis roll AND I want zero camber at the most at full suspension rebound (at my droop setting) Any fixes would be much appreciated as I don't have the time to try every camber link length, tower locations and hub locations combinations. yikes!!
There must be a better trick to this or am I asking for some kind of contradiction for a set up? I don't ever want more then zero camber under roll or full droop setting and I want the correct wheel camber degree of 2 as well. This must be possible.
sn47som1 is offline
Old 03-19-2013, 12:29 AM
  #9237
Suspended
Have you had this car on the track?
ifuonlyknew is offline
Old 03-19-2013, 01:57 AM
  #9238
ekt
ekt's Avatar
I'm not a suspension expert, but with the middle inner and outer most hole in the hub, there is minimal camber change. On my car at least.
ekt is offline
Old 03-19-2013, 11:33 AM
  #9239
Parallel upper and lower wishbones with shorter upper will do what you want. I did not read the whole thing hahahah.
... It may not be the best thing though.
maxflo777 is offline
Old 03-19-2013, 08:13 PM
  #9240
Torian4000's Avatar
Trader Rating: 51 (100%+)
I slapped my buddies old Bitty Losi 2.0 body on. Fits well.
Torian4000 is offline
