Durango DNX408 - Fast enough to win the World Title.
#9076
Ok so some have asked me some questions on my car. here is a bunch of pics hopefully to satisfy
Losi 8ight finisher body
showing how i cut out the body
kyosho arms. when dremeling them make them the right size to where there is no shims needed in the front or rear
the hubs to show how much spacing was needed
a pic of the sway bar attachment. predrill a hole in that location and run a screw through it. works great
#9077
continued
if you cut the bottom tab off the diff case and put a set screw in the top one you can lower the angle of the rear drive shaft. doing so will help with power transfer and life of the cvd.when doing this you will have to cut the battery box as well as some of the tray and grind down the rear motor mount a bit to help clear the drive shaft
i have cut the tray just passed the throttle servo. i left the mounting screw there and cut just passed it
i have relocated a hump pack to the front. using the remaining of the left over tray and using the rear tank riser to secure the battery to the mud gaurd. you can also put a stick pack there and just zip tie it to the mud gaurd. hump pack offers a little more weight up front. as well you can see the servo standing up. use tekno universal servo mounts. work great.will require to drill 3 new holes in the chassis and countersink them. (not for rookies)
another view of the tank riser'
any other questions just ask. feel free to share.
also if you would like a setup sheet that i use as my base feel free to ask and i can email it to you
thanks hope you guys and gals like
#9079
continued
Attachment 1031400
Attachment 1031401
Attachment 1031402
Attachment 1031403
Attachment 1031404
Attachment 1031400
Attachment 1031401
Attachment 1031402
Attachment 1031403
Attachment 1031404
#9080
personaly i felt a big difference with lowering the rear diff angle and putting a stick pack up front.
standing the servo up is only necessary if you want to run a hump style pack lipo
but i would suggest doing the diff mod.. more acceleration..smoother drivetrain.. and smoother accerlation
#9081
#9082
#9083
There is a much easier way to improve the front and rear CVD: Get a set of Mugen 2.5mm pins, cut them to length and slot them and use them instead of the stock TD CVD pins. The stock pins are about 2.4mm and cause slop in the CVD, which returns in wear on the holes in the CVD. With the thicker pins, the slop is gone without any binding and the wear is significantly reduced.
#9084
Ill try and get pics when I do my diffs this week.
#9085
Good find man.
#9086
#9090
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
infractions have been given out. if you are not here to talk about the car you run. you will be leaving this thread.. thank you..
