Durango DNX408 - Fast enough to win the World Title. >
Old 09-14-2012, 05:55 AM
  #8506
Trader Rating: 120 (100%+)
Do you guys put any kind of lube or green slime on the shock o-rings when you install them or should you leave them dry? Just trying to get the smoothest possible shock so any suggestions would be great.
JoeC is offline
Old 09-14-2012, 06:04 AM
  #8507
Trader Rating: 56 (100%+)
Always use lube.... I use red Mobil one grease. Works like a charm...
underway is offline
Old 09-14-2012, 07:01 AM
  #8508
tobamiester's Avatar
Trader Rating: 359 (100%+)
Yes, I generally use AE Green Slime on all my shock and diff Orings.
tobamiester is offline
Old 09-15-2012, 02:53 PM
  #8509
Green slim works well...I use Dow33 because I have a lot left over from my paintball days. Dow33 is used in paintball guns where tolerances are super tight and any swelling of the o-rings will cause problems.
Note - For all you paintballers out there who might be thinking of trying this with your left over grease...make sure you do not use Dow55. A lot of paintball guns out there use Dow55 but Dow55 does cause o-rings to swell.
InspGadgt is offline
Old 09-16-2012, 09:47 AM
  #8510
Trader Rating: 32 (100%+)
Starting to get a handle on my Durango's and very pleased with the durability and performance.
Finished third at round 5 of the Midwest Nitro Series at clark rc park in WI.
Finally found setups that suit my driving style and the feel I was looking for.
madhammer is offline
Old 09-18-2012, 07:39 PM
  #8511
Made a few changes to the buggy today for this coming weekend.
Anyone have any experience with the new Dual Position C-Hubs ?
Been looking at Lutz's LCRC setup.
Also, installed the new White Springs - Red Front, Green Rear - Any opinions ?
Old 09-18-2012, 10:49 PM
  #8512
Default Setup info
Hey all,
I am just now getting into the idea of racing my DNX I am curious to see any setups that make the car neutral. I am looking for a good base setting so that I can start to work off of. I will be running on the JBRL round 6 track here in Chula Vista. Only 1 highspeed corner, the rest are tight. lots of medium sized jumps. Where can I start? Also I seem to always have a car that like to float in the air, and I see everyones seems to drop down nose first rather easily. Is it setup or is there alot of brake action going on?
Thanks for the help!
Speedracer1600 is offline
Old 09-18-2012, 10:52 PM
  #8513
tropy's Avatar
Originally Posted by Speedracer1600
Hey all,
hey speedracer when are you planning to drop by cvrc I want to get my durango running again we can change info there
tropy is offline
Old 09-18-2012, 11:33 PM
  #8514
Im thinking I might get sometime next week this week I am booked but I want to make it a thursday night thing!
Old 09-18-2012, 11:42 PM
  #8515
wombat's Avatar
Trader Rating: 31 (100%+)
Hi guys
what other 36mm clutch/flywheel options are out there besides M2C and Werks clutches that are availabe to buy online? Can't seem to find too much in 36mm available....just bought a werks 'pro' light set-up but want to buy another brand for test/comparison.
cheers
wombat is offline
Old 09-18-2012, 11:59 PM
  #8516
Trader Rating: 40 (100%+)
Buku
M2C
Werks
Ascendancy (JVC)
BrakeTurnAccelerate is offline
Old 09-19-2012, 12:57 AM
  #8517
wombat's Avatar
Is it just me, or have Werks discontinued the 36mm clutch/flywheel kit? No longer listed on their site, and no-one seems to be selling them now?
wombat is offline
Old 09-19-2012, 06:31 AM
  #8518
Trader Rating: 27 (100%+)
After working on the stock clutch and getting very frustrated with the ancient design, I switched to the Buku clutch and I love it! I have several races on it now and the shoes don't show any wear! Plus it is so easy to tune the clutch, just stop the engine, adjust the set screws in the flywheel and fire the engine back up and keep on running! Initially I was very hesitant because of the investment, but in my opinion the ease of maintenance and tuning makes up for the higher cost!
ehartman_49348 is offline
Old 09-19-2012, 06:35 AM
  #8519
I tested with the dual position c-hubs (12 degree) when I initially got the DNX408 and before the new white springs were available and it worked ok. Now that I have the updated springs, I have switched back to the stock (10 degree) c-hubs and the car is more responsive than with the 12 degree c-hubs. I have the white/red fronts and the white/blue rears on my setup, just like the setup from Ryan Lutz at the 2012 Nats. The only difference in my setup is that I did the rear shock mod and went out one shock hole on the tower to get a little more 'pop'. The car is very stable with that setup and can be pushed really hard, especially coming out of turns!
Old 09-19-2012, 08:13 AM
  #8520
EvanAZ's Avatar
Trader Rating: 99 (100%+)
+1
Running this on my 408 also, so much easier to tune and adjust for different track conditions.
EvanAZ is offline
