Durango DNX408 - Fast enough to win the World Title. >
Old 08-28-2012, 08:04 PM
  #8476
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by OnRDPassion
I am thinking about switching over from an associated 8.2 and trying out this buggy, BUT there are no local shops here that carry any Durango parts. I was wondering what the most common parts on this car that go bad are so i can keep an inventory of them in-case anything breaks / bends. Can someone make some recommendations?
Front cvd's, rear center driveshaft, wing mount. I do not recall having any other problems. I only had the latter two failures but others are talking about the front cvd's. Unlike the durango 1/10 scale cars, this one is built like a tank.
jmackani is offline
Old 08-29-2012, 09:16 AM
  #8477
spider882009's Avatar
Trader Rating: 7 (89%+)
Just built a fresh out of the box Team Durango DNX408 kit. Having one small qlitch in getting it running. What battery is everyone using for the transmitter/receiver box that is installed under the rear drive shaft??? Also what bump box is everyone using??? I picked up a Blue OFNA dual motor. Is that the best for this???
Big thing is the Battery tho. Non of my battery packs will fit.
spider882009 is offline
Old 08-29-2012, 09:29 AM
  #8478
Trader Rating: 27 (100%+)
I use this rx pack:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVTE9
There is a small number of LiFe packs that will fit too, but I will have to look up which ones exactly.
As far as the starter box: pretty much any universal starter box should work, just take your time setting it up right. This is done the best/easiest with the engine removed. It took me a few tries, but I could my Duratrax starter box (http://www3.towerhobbies.com/cgi-bin...&I=LXMPP5&P=ML) working great now.
ehartman_49348 is offline
Old 08-29-2012, 09:44 AM
  #8479
Default Thank You!!!
Originally Posted by ehartman_49348
I use this rx pack:
Thank You!!! Never thought of setting up the box like that.
Old 08-29-2012, 11:20 AM
  #8480
Panda-PR's Avatar
http://www.amainhobbies.com/product_...ck-66V-1300mAh
And the ofna box works
Panda-PR is offline
Old 08-31-2012, 11:55 AM
  #8481
Pulse_'s Avatar
What springs would you use on smooth high grip tracks with few bumps/ jumps?
Pulse_ is offline
Old 08-31-2012, 12:05 PM
  #8482
McD44's Avatar
Trader Rating: 16 (100%+)
I'm using the white/red fronts and white/blue rears on a smooth medium grip and they're great.
McD44 is offline
Old 08-31-2012, 12:18 PM
  #8483
Pulse_'s Avatar
I want to be sure to understand (sorry I'm french ). So you use white springs everywhere or red in the front and blue in the rear, right?
I found a weird thing, Ryan Lutz said
"The kit supplied Blue ones are actually stiffer than any of the option kit springs that they currently offer."
So does that mean there are two different types of blue springs for the DNX408?
Pulse_ is offline
Old 08-31-2012, 12:28 PM
  #8484
McD44's Avatar
Nope, referring to the white series of springs.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCMSR&P=X
http://www3.towerhobbies.com/cgi-bin...?&I=LXCMTB&P=X
McD44 is offline
Old 08-31-2012, 12:36 PM
  #8485
Pulse_'s Avatar
Ok... I didn't know there were different series. They had to make things more complicated, one colour is too easy Next year we will have rainbow springs and everybody will be lost . Of course they give no rate either, GREAT
Pulse_ is offline
Old 09-01-2012, 06:52 AM
  #8486
McD44's Avatar
LOL. Well don't forget about the silver series of springs!
http://www3.towerhobbies.com/cgi-bin...E=X&psearch=Go
The white series has a linear compression rate while the silver series is more progressive. I have a set of the silvers too, silver/green front and silver/grey rear. I have yet to test them but as soon as I get me can running again I plan on running the whites and silvers back to back.
McD44 is offline
Old 09-01-2012, 08:10 AM
  #8487
Pulse_'s Avatar
Because of this µ§£µ§¨µ%@^`|[%% PIECE OF SH µ£%µ£§/FUµ%£ING motor mount
Thanks for the springs, put the mount in acid and let it die in atrocious pain
Pulse_ is offline
Old 09-01-2012, 03:14 PM
  #8488
The kit black blues are heavier than the black blues a dunno y this is but i h8ed the kit springs and threw them out
av4625 is offline
Old 09-03-2012, 12:26 AM
  #8489
Oh cool the new springs are finally out! Once I get back into off-road after IIC I'll have to get the LHS to order me some
InspGadgt is offline
Old 09-03-2012, 02:54 PM
  #8490
tobamiester's Avatar
Trader Rating: 359 (100%+)
Finished up my Bulldog body today. Overal pretty happy with the fit.
iPhone photos saturate the colors somewhat.
tobamiester is offline
