Durango DNX408 - Fast enough to win the World Title. >
Old 08-14-2012, 03:50 PM
  #8416
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Has anyone tried the new silver or white springs yet???? What did you think, Thanks!
Bman's 3XNT is offline
Old 08-14-2012, 04:35 PM
  #8417
That's good to know. The DNX looks awesome with that body. Thanks guys
chestonsm is offline
Old 08-14-2012, 05:09 PM
  #8418
McD44's Avatar
Trader Rating: 16 (100%+)
I just put on the silver/blue fronts and white/green rears on. I haven't put any laps down yet with them but I should be doing some testing tomorrow. I'll let you know. I'm using 4 hole B pistons, 35wt rear and 40wt front AE oils FWIW.
McD44 is offline
Old 08-14-2012, 06:03 PM
  #8419
Please let me know. But curious, how did you come up with that combo?
Old 08-14-2012, 06:06 PM
  #8420
McD44's Avatar
From the recommendation of an experienced driver. The F:R spring rate ratio is the same as the ratio that Lutz ran at Nats. Since those springs aren't out yet these are the closet rates that retain the ratio.
McD44 is offline
Old 08-14-2012, 06:10 PM
  #8421
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
I know this isn't the for sale thread but was hoping to give some one a good deal if they were looking for them.....
I paid $53 at Amain plus shipping...
http://www.rctech.net/forum/r-c-item...08-dnx408.html
Posvar is offline
Old 08-14-2012, 08:45 PM
  #8422
Originally Posted by jmackani
fuel was not a problem with this losi body
Originally Posted by ehartman_49348
That looks great!! Is that the stock DNX408 tank?
Kyosho fuel tank from what i've seen
Nick411 is offline
Old 08-15-2012, 03:33 AM
  #8423
McD44's Avatar
This was asked in the DEX forum by another poster but I thought I'd ask it here.
Is anyone not running the +2mm rear mod? If you aren't can you explain why? I'm going to try it out today to see if I notice any difference.
McD44 is offline
Old 08-15-2012, 04:56 AM
  #8424
Trader Rating: 358 (100%+)
I test fitted an old D8 bulldog body looks pretty good.
jmoneym is offline
Old 08-15-2012, 05:31 AM
  #8425
Trader Rating: 27 (100%+)
Lutz' 2012 Nats setup uses White/Red (front) and White/Blue (Rear).
White/Red spring rate is 103
White/Blue spring rate is 87
Front to rear ratio is 1.1839
Based on the stiffest TD springs currently available, which is the Silver/Blue (front) with a spring rate of 97. Use the front to rear ratio and you end up with 81.9, which leaves the options of White/Green (81) or Silver/Green (88), hence the combination of Silver/Blue (front) and White/Green (rear) combination....
I figured this would be a better combination than any of the other TD spring combinations until the White/Red and White/Blue are available in the US.
ehartman_49348 is offline
Old 08-15-2012, 06:41 AM
  #8426
jmackani's Avatar
Trader Rating: 14 (100%+)
Wow, so that really does not leave much on the prototype that is not kyosho. Probably only the drivetrain and chassis.
jmackani is offline
Old 08-15-2012, 10:09 AM
  #8427
From the looks of Jorn's car at the euros, the Kyosho part list on the prototype seems to be shocks (front, rear, stand offs), front suspension (arms, caster blocks, hubs, drive shafts), and the fuel tank. Other than that it looks to be all durango prototype parts.
http://gallery.neobuggy.net/2012Race...4178&k=h8j7JZk
Nick411 is offline
Old 08-15-2012, 05:53 PM
  #8428
Ive searched this and i have not found a answer..
is anyone else having problems with bending the front drive shafts due to the dog bone locking out in the out drive when the shock is fully compressed.
i was just gonna limit the up travel of the shock by using shims but i just wanted to see if anyone else is using different shock bottoms to compensate for this.
GomerPile2525 is offline
Old 08-16-2012, 07:28 AM
  #8429
For those who were waiting for the springs that Ryan Lutz used on his 2012 Nationals setup, they are now in stock (limited quantities) at Tower Hobbies:
http://www3.towerhobbies.com/cgi-bin...6674&search=Go
http://www3.towerhobbies.com/cgi-bin...6642&search=Go
Old 08-16-2012, 09:41 AM
  #8430
McD44's Avatar
Yep, placed my order this morning. Also grabbed silver/gray rears to match up with my silver/blue fronts to have a softer but more progressive set for fine tuning to track conditions.
McD44 is offline
