Durango DNX408 - Fast enough to win the World Title. >
Old 05-30-2012, 07:31 AM
  #8041
BrNeeto's Avatar
Originally Posted by stg099
Aluminum horn is the only way to go in my opinion. I run my servo saver as tight as it can go. If you run it even slightly loose you will loose steering on bumpy/rutty tracks.
Hnn..
Okay, I will go buy the Aluminum horn.
Thanks for your help!
BrNeeto is offline
Old 05-30-2012, 09:08 PM
  #8042
KarBro's Avatar
Originally Posted by Dozey83
Hi, no they don't,
you need to use the stick pack type
Rob
Thank you for the information, I have a stick pack, thinking of getting another pack, longer drive sessions when I do get some time of from home to have some "daddy time".
Cheers!
KarBro is offline
Old 05-31-2012, 06:49 PM
  #8043
tobamiester's Avatar
Trader Rating: 360 (100%+)
Team Durango Exhaust Manifold Support Set - TDR290008
Couldn't figure out how to mount this thing until now when i noticed my 2090 resting on the v2 radio box...
Figured I'd post some pics for those interested. Couldnt find any on here when I looked...
tobamiester is offline
Old 06-01-2012, 12:40 AM
  #8044
Huleboer's Avatar
I suppose the support is to help the manifold clear the battery box, but it has a grave issue.
It will eat your manifold because of vibrations.
Even though I used fuel tubing on the support it ate almost completely through the manifold before I noticed, and that was only on a few days racing.
I would get rid of it ASAP.
Huleboer is offline
Old 06-01-2012, 12:55 AM
  #8045
Dozey83's Avatar
I think its not supposed to be in constant contact with the manifold, but in a position that if you crash heavily or get hit on the side its supposed to stop the manifold from contacting the radio box.
I personally don't use one, but that's mainly as i use that hole in the chassis to locate on my starter box!
Dozey83 is offline
Old 06-01-2012, 04:40 AM
  #8046
Ah..thats good advice. ok, then maybe I'll get rid of it. Seemed like a good idea on paper thanks guys
Old 06-01-2012, 07:03 AM
  #8047
Limywidget's Avatar
+5000....get rid of it. It will destroy everything in its path. I tried using fuel tubing and it destroys it as well.
Limywidget is offline
Old 06-02-2012, 11:21 AM
  #8048
KarBro's Avatar
Hi there, I have a question about the KO Propo Switch 2, is there anyone running it on the DNX 408 V2 version? If you are how have you mounted it? Pictures would be good.
Cheers!
KarBro is offline
Old 06-02-2012, 12:32 PM
  #8049
When will the white springs be available? shud be soon now the truggys out?
av4625 is offline
Old 06-02-2012, 09:14 PM
  #8050
Fresh paint on a new J-Concepts body for my Dingo!
InspGadgt is offline
Old 06-04-2012, 06:06 PM
  #8051
cartodinamo's Avatar
Cheers!
this is how I do it, I'm using the v1 transponder support.....
the next option it's to put it directly on the side guard.
cartodinamo is offline
Old 06-04-2012, 10:37 PM
  #8052
KarBro's Avatar
[QUOTE=cartodinamo;10819982]this is how I do it, I'm using the v1 transponder support.....
QUOTE]
Cheers and thanks for the picture!
KarBro is offline
Old 06-11-2012, 12:49 AM
  #8053
Still no word on the new springs???? I'm getting tired of the Kyosho springs which don't fit well.
Old 06-11-2012, 02:07 AM
  #8054
same i want the whites!!!!!!
av4625 is offline
Old 06-11-2012, 12:26 PM
  #8055
Trader Rating: 6 (88%+)
Default ???
Anyone know the part number for the front drive shafts and what the length is? Not the center front drive shaft but the ones for the front axles? Thanks for the help
Drip is offline
