Durango DNX408 - Fast enough to win the World Title. >
Old 04-14-2012, 06:57 PM
  #7786
KinzR's Avatar
wow I didn't realise that towerhobbies had so many dnx parts in stock... and what exactly is this...
http://www3.towerhobbies.com/cgi-bin...?&I=LXCCMP&P=7
KinzR is offline
Old 04-14-2012, 07:21 PM
  #7787
Limywidget's Avatar
It's a bag full of Ryan Lutz fairy dust. Just in three sizes. Sprinkle on your buggy for a performance like Ryan's. Works for heats, not main's....sorry. And if you purchase the Alpha Lutz engine the dust will tune the engine automatically to current temperature, humidity, and elevation conditions....
On a serious note, that is curious...
Limywidget is offline
Old 04-14-2012, 09:06 PM
  #7788
Trader Rating: 14 (100%+)
My "guess" would be it is all the parts to make your original 408 the "new" V2.....tank, radio box, fuel cooler, throttle mount, etc....
rpmhobbies is offline
Old 04-14-2012, 09:08 PM
  #7789
Originally Posted by Iggy 102
Do any of you guys run the 2mm wider hexs if so which end what improvements do you see?? I ended up with a couple sets woundering if I should run them or not
The ass end doesnt "snap" around as quickly....
Old 04-14-2012, 09:57 PM
  #7790
so only run them on the rear
Iggy 102 is offline
Old 04-15-2012, 01:16 AM
  #7791
beanforge's Avatar
If your search "Durango DNX408 Update Bag" your come across part numbers TD290014, 15 and 16. These are PNs for updated turnbuckles. I'm guessing that's all it is...
I've been wrong before.
beanforge is offline
Old 04-15-2012, 04:27 AM
  #7792
I think the part numbers for the turnbuckles has been revised to TD310214, TD310215 and TD310216
Chris-s is offline
Old 04-15-2012, 04:44 AM
  #7793
Default New Option parts now on TD Site
New Springs:
http://www.team-durango.com/search.p...s=silver&Go=Go
http://www.team-durango.com/search.p...ms=white&Go=Go
Also HD hinge pin holders:
FF: http://www.team-durango.com/part-inf...artNo=TD330368
FR: http://www.team-durango.com/part-inf...artNo=TD330369
RF: http://www.team-durango.com/part-inf...artNo=TD330370
RR-R: http://www.team-durango.com/part-inf...artNo=TD330371
RR-L: http://www.team-durango.com/part-inf...artNo=TD330372
Dual Position C-Hubs:
http://www.team-durango.com/search.p...position&Go=Go
Chris-s is offline
Old 04-15-2012, 08:05 AM
  #7794
What is about the new HD suspension holders? was there any problems with the old ones?
Got answer. there is more material around the plastic insert.
putte_Rolf is offline
Old 04-15-2012, 08:45 AM
  #7795
Pulse_'s Avatar
Anyone having troubles ripping his shock diaphragms ref. 330097 ?
Just wanted to change my shock oil and all 4 are ripped. Did I do a mistake here or is it a known problem?
Pulse_ is offline
Old 04-15-2012, 09:35 AM
  #7796
Limywidget's Avatar
Known issue. I have been using Losi bladders with no trouble...
Old 04-15-2012, 10:01 AM
  #7797
The bladders have been updated to solve this problem.
Chris-s is offline
Old 04-15-2012, 10:07 AM
  #7798
Pulse_'s Avatar
Good to hear, thanks. Lets hope I'll have the good batch if I order them online.. I might go for the Losi if they are a direct fit, just to make sure.
Is there any other known issue on the v1 version except everything related to the nitro version (I'm running a conversion)?
Pulse_ is offline
Old 04-15-2012, 10:18 AM
  #7799
Trader Rating: 40 (100%+)
Just go with the Losi ones. I doubt you'll get the new ones if you ordered it online.
BrakeTurnAccelerate is offline
Old 04-15-2012, 12:02 PM
  #7800
Pulse_'s Avatar
I will, thanks
Pulse_ is offline
