Durango DNX408 - Fast enough to win the World Title.
#7771
ok so again i'm not really sure what's going on, but at least i have narrowed it down alot from my last post. Front diff is good, center diff is good, but rear diff is giving me the grief. I have pulled out and refilled the diff 3 times now, so it is put together properly and spins fairly well out of the chassis. The rear hubs spin nice and free when out of the diff, but when i put the shafts in the rear diff everything gets near impossible to turn with fingers, and on both sides of the diff. I don't know what i did, but the rear diff in the chassis is giving me grief, and i don't know what to do because it should not be this tight
#7772
#7773
#7774
one of my first thoughts were the driveshafts, but they are 96mm back and 94mm front. Here are the pics
#7775
and the last 2 i took .... i took the sway bar offf and the arms off to be sure nothing else could be binding
#7776
-Did you use two grub screws on the centre driveshafts?
#7777
Pull the outdrive covers/sleaves out (should be about flush with end of outdrive).....looks like they may be pushed into the 'shell'. Also check for any flashing etc on it that is left over from the molding/parts tree.
#7778
#7780
Looks like the whole Durango/Hobbico thing is finally starting to happen..
http://www.towerhobbies.com/products...drc0210_e.html
#7781
Crap that reminds me...One of my front boots tore and i forgot to order new ones.
#7783
Amazon is clearing out V1s for $292.12...
Ten remaining:
http://www.amazon.com/Team-Durango-D...4352179&sr=8-1
Ten remaining:
#7784
Any who has i good Astro Tuft track setup for the dnx408?
#7785
Do any of you guys run the 2mm wider hexs if so which end what improvements do you see?? I ended up with a couple sets woundering if I should run them or not
