Durango DNX408 - Fast enough to win the World Title. >
Old 04-12-2012, 02:38 PM
  #7756
jsp619's Avatar
Originally Posted by CoryD
Bar NONE, MP9 is the best buggy on the planet! Let's get this thread back to on track a bit:
What hop-up parts are must-have for this car -- minus the seemingly defunct V2 radio tray since lutz ran the batt up front now.
Later,
This is not an MP9 thread buddy.
jsp619 is offline
Old 04-12-2012, 02:43 PM
  #7757
CoryD's Avatar
I know just being a dingus.
I have a small shop and I am trying to figure out what parts to bring in to support the durango guys.
Later,
CoryD is offline
Old 04-12-2012, 02:53 PM
  #7758
jsp619's Avatar
Later,
Awesome is that your online shop address in your signature? ill check it out if you got stuff in stock ill be ordering. i would suggest you get your hand on all the V2 stuff you can. IE radio tray, fuel tank, exaust cooler. and so on.
jsp619 is offline
Old 04-12-2012, 02:59 PM
  #7759
CoryD's Avatar
I'm in Canada -- because of double-duties I would suggest that you continue to support your LHS or shops like a-main etc.
I am really just trying to get the correct stock in so that I don't leave the racers in my neck of the woods hanging.
Later,
CoryD is offline
Old 04-12-2012, 03:46 PM
  #7760
Later,
Unless they make a TKi777 that includes a Tebo, its the same POS as everything else. Go troll out your shop's customers.
maxflo777 is offline
Old 04-12-2012, 03:49 PM
  #7761
CoryD's Avatar
I'm just trying to find some information here; didn't mean to offend anyone...lol!
Later,
CoryD is offline
Old 04-12-2012, 08:06 PM
  #7762
Later,
Yeah right.
Old 04-12-2012, 09:23 PM
  #7763
I'm not really sure if anything is wrong, but the buggy i just finished putting together just doesn't "feel" right. Are the diffs supposed to feel very stiff when this kit is new? Right now when i put the buggy on the ground i can't just throw it and have it keep coasting, it goes for about 6" before it stops, maybe less. I have to push it and almost hold it down or the tires will slide on the ground. Did i maybe do womething wrong or are tight diffs common? Or should i be looking somewhere else maybe because i'm sure i put it all together correctly according to the manual
thanks for the help guys!
nitroharry is offline
Old 04-12-2012, 09:40 PM
  #7764
ekt
ekt's Avatar
One thing to check is if you put the inserts in the diff the right way around, the flat side faces inwards.
ekt is offline
Old 04-12-2012, 10:42 PM
  #7765
magnuts's Avatar
Sounds like the axles may be too tight. The manual shows to put 2 of 10x16x0.1mm shims on the inside of the axle. Try removing one of the 10x16x0.1 shims from the inside if the axle. The axle should rotate freely in the hub carrier.
There should be very little resistance of any of the rotating components.
magnuts is offline
Old 04-12-2012, 10:48 PM
  #7766
Also i would check the shims out at the hubs. I know the Manual says to put one small shim between hex and the hux. and two bigger between the hub and wheel axle.
I found out that only with the small shim between the hex and hub worked otherwise it was binding in the drivetrain.
I guess this is something people shim when the car have drive a while when it start to get loose?
putte_Rolf is offline
Old 04-12-2012, 10:55 PM
  #7767
cartodinamo's Avatar
Also check if you use any shims between your diff and the diff case, you don't need any in a brand new car.
When new the diffs need a liitle break in to come fully smoth but not as hard as you posted.
Hope it helps, enjoy your car.
cartodinamo is offline
Old 04-13-2012, 03:50 AM
  #7768
Anyone have some info about the new springs? I saw at ryans setup that he used a "new" silver/black spring
Anyone know if there is coming up a whole new line with springs that will replace the old ones, or just a few pairs of new springs? also what have they made different about this 2 color springs than the stock ones?
Old 04-13-2012, 04:15 AM
  #7769
DRCRacer299's Avatar
The new springs will be complementary to the current 'black' set. Personally I never thought I would run the black springs again. But at Neo I ended up running the absolute softest one black/black on the rear of my buggy.
The new sets are stiffer and more progressive than the 'black' set. Not sure off hand how many there will be. I would say as many as 4 in a silver set and as many as 8 in a white set. We will see soon!
DRCRacer299 is offline
Old 04-13-2012, 08:14 AM
  #7770
jsp619's Avatar
Whats the ETA on the new spring sets?
jsp619 is offline
