Durango DNX408 - Fast enough to win the World Title. >
Old 03-28-2012, 07:05 PM
  #7666
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Originally Posted by jmackani
You have it reversed. Set the droop then the ride height. If you do it in the order you suggested, then step 3 would be to reset your ride height.
I'm not sure you are correct but you should check your ride height often either way. I wasn't really giving an order just what does what.
Jon Carlson is offline
Old 03-28-2012, 07:06 PM
  #7667
meaN1's Avatar
Trader Rating: 15 (100%+)
nub question here, I have a dnx408 that I am converting to brushless and am curious as to what diff fluid i should be using, i cant seem to find any local places that have it here in the states and wondering what is comperable fluid i should be using to rebuild them
meaN1 is offline
Old 03-28-2012, 07:23 PM
  #7668
Rock333's Avatar
Trader Rating: 51 (100%+)
http://www.rcrcr.com/index.php?optio...eral&Itemid=46
Rock333 is offline
Old 03-28-2012, 07:56 PM
  #7669
Thumbs up
Hey new guys to durango, I threw together a beginner parts list from all the pages I've been reading, these parts should set you in the right direction.
I have...
1. screws for the 2mm rear mod, it will be good to use these longer screws as advised by team durango TDR704022
2. 2mm rear mod shims, I found the size of shims that are the exact same size recommended by team durango, the shims recommended by td are on back order at the moment OTR-R550727-10
3. protek 2300 receiver battery, this battery fits good it was recommended to me by Ryan and seems to be a great battery! just remember to use a LIPO charger! Also may want to look into a losi voltage regulator to add to it
PTK-LP-RX2300-L-2S
4. 70 MM shock springs, as posted by many people It looks like the light blue and light green are the combinations mostly used to I sent links to both, as long as they are 70mm size kyoshos they should fit ( for me they did )
KYOIF350-816 light green and KYOIF350-714 light blue
5. Version 2 receiver box (on backorder at the moment)
TDR320120
6. Search dnx408 on amainhobbies and take a look at the spare parts get what you think you'll need they are cheap if you ask me
spencey820 is offline
Old 03-28-2012, 08:02 PM
  #7670
jsp619's Avatar
[QUOTE=spencey820;10530231]Hey new guys to durango, I threw together a beginner parts list from all the pages I've been reading, these parts should set you in the right direction.
6. Search dnx408 on amainhobbies and take a look at the spare parts get what you think you'll need they are cheap if you ask me[/QUOTE
+1
Parts for this car are incredilbly in expensive for an 1/8 scale
jsp619 is offline
Old 03-29-2012, 07:44 AM
  #7671
Limywidget's Avatar
[QUOTE=jsp619;10530252]
+1
Jenny's RC on ebay.....1st
Amain.....2nd
Limywidget is offline
Old 03-29-2012, 01:12 PM
  #7672
Trader Rating: 50 (100%+)
Bladders work fine if you put them in the shock body and then screw the cap on. If you put them in the cap and then screw on, they get cut.
Aluminum servo horn will be needed for steering.
Buy the updated wing mount which will include the new front bumper.
Buy an extra rear center drive shaft also. Kit ones were hit or miss for failing. Most people are running kyosho springs also. Unless you buy the V2 kit, none of the updated parts are in the other kits. I bought mine even after about a year and none of the updated parts were in the kit.
APpreciate the tips here, looking forward to the build!
stg099 is offline
Old 03-29-2012, 09:51 PM
  #7673
Wernimont's Avatar
Originally Posted by cartodinamo
Hello Carson, you're welcome!
Can you talk about your nitro challenge shock setup and your findings with the kyosho shocks-springs???
You make a very good race, congrats!
Sorry I couldn't reply sooner. Its been a little crazy around hear with cactus just last week.
At Nitro Challenge I was running the Kyosho shocks and springs in the rear because we are testing new geometry on the 408 line of vehicles.
Wernimont is offline
Old 03-29-2012, 10:00 PM
  #7674
Wernimont's Avatar
I cant attach any links yet, but if anyone wanted to know my set up from Nitro Challenge its on Team Durango's website. Just go In the Pits, pick the DNX408v2,Pick USA for the country, and then pick The_Dirt for the track, and then pick Carson Wernimonts 2012 Nitro Challenge set up and let the fun begin!
Old 03-30-2012, 06:24 PM
  #7675
jmackani's Avatar
Trader Rating: 14 (100%+)
http://www.team-durango.com/pdf/setu...t_26_02_12.pdf
jmackani is offline
Old 03-30-2012, 08:41 PM
  #7676
Konich's Avatar
So Green Kyosho springs in the front and Light Blue in the back?
Konich is offline
Old 03-31-2012, 12:45 AM
  #7677
yep light green front and light blue rear
im using kyosho light blue front and orange rear with losi csi (gen2) blue pistons on a loose bumpy track, works well
hipster is offline
Old 04-02-2012, 03:57 PM
  #7678
Well my DNX408 was working the best it has this past weekend! I still have some tweaking to do on the setup but it is getting really close so I figured it was time I get some new stuff for it. Ordered me a new engine and also the Ascendency clutch...so I was wondering what springs I should start out with...the stock DNX408 springs were a bit too stiff for me so I went to the Mugen .9 springs which are a bit too soft...so I am looking for something in the middle of that.
InspGadgt is offline
Old 04-02-2012, 05:02 PM
  #7679
Trader Rating: 40 (100%+)
Depends on which engine you're going to be running. I would say 4 x .95 would be about right. That was my base setup for the M2C clutch.
BrakeTurnAccelerate is offline
Old 04-02-2012, 05:20 PM
  #7680
Panda-PR's Avatar
Hi, I'm ready to order the kyosho springs and just noticed that both say front shocks:
(Light Blue) (2) (KYOIF350-714) and 70mm Big Bore Front Shock Spring (Light Green) (2) (KYOIF350-816).
No problem with them being both for the front? Sorry, noob
Panda-PR is offline
