Durango DNX408 - Fast enough to win the World Title. >
Old 03-25-2012, 04:39 AM
  #7636
TrickyMick's Avatar
Default Too Team Durango
With the new DNX408 V2 on its way, will the Current version be cheaper still?
or
Will you offer the Upgraded parts as an option to buy as a package?
or
Will they be included them in any Older Model Kit Sold????
TrickyMick is offline
Old 03-25-2012, 06:25 AM
  #7637
tobamiester's Avatar
Trader Rating: 360 (100%+)
or
or
Original kit is still $370 from Amain. I would say get one while you can at that price. I imagine they will sell all the old stock and then you will have to pay the original price i.e $549 for the new kit.
Cost of new parts is (roughly) just = $22 tank, $12 radio, $15 gearcase, $6 wing mount, Figure $4 or PT-mount, $3 bladders = $62.
tobamiester is offline
Old 03-26-2012, 01:08 AM
  #7638
Trader Rating: 16 (100%+)
Default Anti squat
Hi all 408 drivers,
May I know which anti squat inserts u guys use for RR block ?
I m using 3/3 and car squat alot. My LHS run out of the part 330303.
I wonder when the car squat a lot it will affect the front traction.
Any input ??
rossii is offline
Old 03-26-2012, 12:00 PM
  #7639
Trader Rating: 66 (100%+)
Does anyone happen to know of any hobby shops in southern California that carry 408 replacement parts? Heading out there and hoping to find some hinge pins for backups.
dr_gonzo is offline
Old 03-26-2012, 02:33 PM
  #7640
Rock333's Avatar
Trader Rating: 51 (100%+)
www.losipartshouse.com
Near Long beach.
Rock333 is offline
Old 03-26-2012, 02:58 PM
  #7641
Near Long beach.
Thanks!
dr_gonzo is offline
Old 03-27-2012, 01:00 PM
  #7642
Quick question how are people measuring the shock length.
My shocks i cant seem to get under 126mm which is making my ride height silly, im trying to put doughty's slough setup on there which calls for 116mm shock length but cant get any where near that!
Slick990 is offline
Old 03-27-2012, 01:06 PM
  #7643
The shock length is measured on the car it is taken from the screw holding the shock to the wishbone too the upper shock holder it can be adjusted using the droop screws
kbrunsden is offline
Old 03-27-2012, 01:11 PM
  #7644
Only thing im having with that is im ending up with a ride height of about 30+mm when the setup sheet calls for 24mm. But should the shock length be independent from the droop screws as thats another setting?
Slick990 is offline
Old 03-27-2012, 01:20 PM
  #7645
Shock length is controlled with the droop screws. You will need to adjust the spring collars (gold bits on the shock bodies), to adjust for ride height.
Chris-s is offline
Old 03-27-2012, 01:22 PM
  #7646
And what adjusts the droop?
Ive come from a few years of touring cars, where we would never use a droop screw to limit the length of a shock as that would be set through the actual shock itself off the car.
Do you set the droop first, then the shock length or the other way round?
Slick990 is offline
Old 03-27-2012, 01:53 PM
  #7647
jsp619's Avatar
Droop is the shock lenth the ride hieght should come from the shock adjustment collars, you should first set the shock length or droop first with the droop screws that go through the arms and hit the chassis, then adjust the ride height with the amount of preload on the gold shock collar, if you can not obtain the correct ride height with the shock collars adjusted you have to much rebound built into the shocks.
jsp619 is offline
Old 03-28-2012, 07:50 AM
  #7648
CoryD's Avatar
What touring car would THAT be?
Later,
CoryD is offline
Old 03-28-2012, 08:15 AM
  #7649
vito's Avatar
is this a nice buggy to get and will the updated v2 parts fit? need a 1/8 buugy
vito is offline
Old 03-28-2012, 08:25 AM
  #7650
Yes and Yes
