Durango DNX408 - Fast enough to win the World Title. >
Old 03-08-2012, 11:21 PM
  #7561
Huleboer's Avatar
Originally Posted by MPB408
I have my steering centered, but now it seems as if the wheels are not turning very far. Is there any way I could get them to extend further left and right?
Your controller might have a low rate, or EPA (end point ajustment) is off.
I drove aroung with my radio set to 70% a long time and couldn't understand why it fell dull.
Tjek all the setting of your radio. You really need to read the manual completely and understand what it is capable of. Otherwise you'll never get it running good.
Huleboer is offline
Old 03-09-2012, 01:36 PM
  #7562
jackdani's Avatar
finally i got my new buggy all set and ready to race!
I have been preparing this return to nitro for months..
tomorrow the first ride...
new fuel tank and radio box..also got new bladders for the shocks..
powered by Rb F11
and savox 1257/1258...
this car is so impressive....
jackdani is offline
Old 03-09-2012, 01:38 PM
  #7563
jsp619's Avatar
Default Brakes
Hey guys i just built my 408 and my brake pads do not touch the discs at all is there a trick to building these???
jsp619 is offline
Old 03-09-2012, 01:51 PM
  #7564
Trader Rating: 40 (100%+)
Do you have the shim between the bolt heads and the brake pads? If you don't you need them. If you do, make sure they are screwed in far enough. You could also add more shims, or use a thicker one.
BrakeTurnAccelerate is offline
Old 03-09-2012, 02:19 PM
  #7565
Default csi shock pistons
Has any one tried the losi one's yet?
hipster is offline
Old 03-09-2012, 02:31 PM
  #7566
t8rtot's Avatar
Trader Rating: 14 (94%+)
i cannot stress enough going to lutzinator.com and to the tips section on the durango site. alot of good info there, and answers to almost all questions
t8rtot is offline
Old 03-09-2012, 02:34 PM
  #7567
jsp619's Avatar
Forgive but what shims?? i dont see the use of any shims in the manual? What shims are you guys using???
jsp619 is offline
Old 03-09-2012, 02:38 PM
  #7568
Goto the tips section on the durango site
hipster is offline
Old 03-09-2012, 02:41 PM
  #7569
jsp619's Avatar
There is nothing on either site about this problem.
jsp619 is offline
Old 03-09-2012, 02:48 PM
  #7570
team-durango.com/blog/2011/03/03/dnx408-brake-shimming/
hipster is offline
Old 03-09-2012, 02:49 PM
  #7571
jackdani's Avatar
i needed to put 1.3mm shim between the screw and the pad,
put shims, do not overtight the screws...
if you look closely you can see the silver shim
jackdani is offline
Old 03-09-2012, 03:02 PM
  #7572
a lot of people are also doing this
team-durango.com/blog/2011/04/19/2mm-rear-roll-centre-dnx408/
hipster is offline
Old 03-09-2012, 04:39 PM
  #7573
jmackani's Avatar
Trader Rating: 14 (100%+)
If you switch to the losi brake pads and tighten the screws enough, you will not need any shims. Just another option.
jmackani is offline
Old 03-09-2012, 05:27 PM
  #7574
The black losi brake pads work great and im not using any shims.
evolution03 is offline
Old 03-09-2012, 07:24 PM
  #7575
t8rtot's Avatar
I guess I shouldn't have had faith in you actually looking thru the site since you can't use the search function on here or google.
I don't have all the answers but I won't steer you wrong in where to find them
t8rtot is offline
