Durango DNX408 - Fast enough to win the World Title. >
Old 11-23-2011, 03:32 PM
  #6916
Well my new starter box came in today...I ordered the Dynamite one that is setup much like the Ofna Truggy starter box but I liked the triple guide slots better on this...now to get off work so I can go home and set it up The one issue I have with it so far is minor...but the crimp connectors on the power switch are at a 90* angle instead of straight so the switch doesn't want to set flat in the housing. I'll have that remedied soon as I can stop by the electronics shop on my way home and get new connectors.
InspGadgt is offline
Old 11-23-2011, 03:52 PM
  #6917
Integra's Avatar
Solder the wires, Screw Connectors.
Integra is offline
Old 11-23-2011, 04:25 PM
  #6918
Trader Rating: 40 (100%+)
+1. We've smoked a few starter boxes due to crappy connectors.
BrakeTurnAccelerate is offline
Old 11-23-2011, 04:48 PM
  #6919
jmackani's Avatar
Trader Rating: 14 (100%+)
Shipping cost are too high to order direct.
jmackani is offline
Old 11-23-2011, 07:05 PM
  #6920
http://www.absolutehobbyz.com/produc...oducts_id=7585
Old 11-23-2011, 08:00 PM
  #6921
mjealey's Avatar
Well guys, I was running the Kyosho light blue springs on the front, and the lime green on the rear and no matter what I tried I could not get to the 27mm ride height. The buggy fel pretty good with these springs but I decided to flip them. If you put the lime green in the front and the light blue in the rear it is easy to get to the 27mm ride height. I will see how this feels as I will be running in oractice for a while and a race on Saturday. 4 hrs. of track time and I will be anxious to see what this feels like if it feels any different. I hope it will be better considering my ride height is 3 - 4mm lower now!!!!!
mjealey is offline
Old 11-23-2011, 09:12 PM
  #6922
That's what Ryan talked about a couple of pages back Let us know how it works
Originally Posted by DRCRacer299
Hey guys,
I have some findings that i'm learning as I visit new tracks. I find I am liking running light green front and light blue fronts in the rear, Kyosho springs on tracks that are rougher. Also moving the shocks inside on the arm on the rougher tracks is helping as well.
So on highbite and smoother tracks I am liking the Dark blue fronts and the light green fronts in the rear along with shocks on the outside holes on the arms.
I still like the A piston 3 hole front and rear but I can see the advantage of doing B piston 3 hole on a rough track!
Good luck to everyone racing this weekend!
chirivita is offline
Old 11-24-2011, 12:46 AM
  #6923
Oh I did The wiring looks really slick now. The only place I left the crimp connectors is where it connects to the switch...with the plastic housing of the switch you just can't solder it without ruining the switch...did that once. Also I left tuning fork connectors on the contact plates. Other than that it is all soldered and done up neatly. I had to move the wheel as far to the right it would go and line up the car 2mm to the left of center. So far in testing it works very well...looking forward to trying it out on Sunday
Old 11-24-2011, 07:11 AM
  #6924
Integra's Avatar
Unfortunately You have left out essentially the most important joints that Need soldering to really have a good connection. IF your melting the switch contact's your holding the heat there WAY too long.
Integra is offline
Old 11-24-2011, 07:17 AM
  #6925
BMenard17's Avatar
Trader Rating: 88 (99%+)
+1 and tinning your connections is also very important.
BMenard17 is offline
Old 11-24-2011, 09:21 AM
  #6926
Default Kyosho Springs
I can't get them to fit around the gold shock collars. How do y'all do that? I'd have to file down the collar or use another brand?
mtwinste is offline
Old 11-24-2011, 10:40 AM
  #6927
they will pop on there just use a screw driver or something no need in filing. they will fit its just tight.
so i got the blue fronts on mine. its way to high. i have read some of you all saying that it would be anyone had any luck getting it down to 27mm with blue fronts ?
evolution03 is offline
Old 11-24-2011, 10:42 AM
  #6928
I am aware of that...but it isn't the contacts that are melting it is the plastic housing that holds the contact. The plastic isn't as thick as say Deans connectors and melts extremely easily. Soldering a 16awg wire is going to require too much heat to get the wire attached. The thinner wire of a circuit board would be easy to solder on but not 16awg wire.
Old 11-24-2011, 10:47 AM
  #6929
drs92's Avatar
Trader Rating: 45 (100%+)
Happy Thanks fellow Durango drivers, wish you all the best
drs92 is offline
Old 11-24-2011, 12:53 PM
  #6930
Originally Posted by Kolunatic
Again my buggy was hooked last weekend,I wasn't.it's hard to get track time lately.
Track is very technical,hard packed, little dusty on outer edges,it held moisture very well on cloudy day.was traction rolling one qual and wrecked everywhere. Signed up for intermediate but not enough so was put in with experts, didn't go over well with some would've done better if I had ran my race instead of watching behind me, I didn't want to hear any complaining.
I've been running shocks out on arm in on tower, tried middle on tower due to amount of jumps but went back to inside.
Med cityblocks
Diffs 5,7,3
Sway bars- thickest,fr and rear
B pistons - 3 hole all around
45wt front,40wt rear
10 caster
-2 camber all around,toe out 2
Now if I can get more track time I may be able to catch up with my buggy!
45 and 40 wt seems very hard.
What is your oil brand ?
M357 is offline
