Durango DNX408 - Fast enough to win the World Title. >
Old 08-01-2011, 09:58 AM
  #5491
Originally Posted by dark
ANTI-ROLL bar on rear, ammo on rear WFT
tnx Italian Dealer and Fioroni
Where do you get these, I need them asap since I run my shocks on the rear...
I like it very much, I just hope it doesn't take 12 months to make them available in the states...
Norbert50p is offline
Old 08-01-2011, 10:24 AM
  #5492
dark's Avatar
in USA I think it will not be available, you must contact the Italian Dealer
dark is offline
Old 08-01-2011, 12:01 PM
  #5493
Ciao interessa anche a me il portabarra posteriore, dove lo posso trovare? grazie
uninc is offline
Old 08-01-2011, 12:21 PM
  #5494
dark's Avatar
manda email ad RCSUPERMARKET.it
dark is offline
Old 08-01-2011, 03:02 PM
  #5495
garen's Avatar
Fioroni Durango parts are arriving in the US next week-
http://www.fioroni-usa.com/news%20aug%201.html
garen is offline
Old 08-01-2011, 03:28 PM
  #5496
grazie dark
uninc is offline
Old 08-01-2011, 06:02 PM
  #5497
G_WORD's Avatar
Trader Rating: 124 (100%+)
anybody looking for new 408 parts for cheap here is the link.
http://www.rctech.net/forum/r-c-item...parts-lot.html
G_WORD is offline
Old 08-02-2011, 06:40 PM
  #5498
Kolunatic's Avatar
Hey hogman, what did you say you liked for a starting setup on the m2c clutch? I just got mine today!
Kolunatic is offline
Old 08-02-2011, 07:16 PM
  #5499
hogmansp's Avatar
Trader Rating: 47 (100%+)
Large open outdoor hardpack dusty I liked the 4 1.0 springs with 2 hard and 2 med shoes. Tighter technical tracks am am liking 2 1.0 with med shoes and 2 .9s with hard shoes. I am going to start out with the 2 1.0 and 2 .9 spring setup this weekend at the Chicago RCX expo since it is a small indoor track layout. Weight I have been running the center ring loaded and every other one on the outer ring.
hogmansp is offline
Old 08-03-2011, 02:44 AM
  #5500
Kolunatic's Avatar
Thanks, I only have the shoes that came with kit. I guess I'll start with different springs.technical hard packed track. I was hooked on stock clutch, gotta get to track early to experiment.hope it doesn't take long to dial in.
I also had contacted nankinhobby thru website but still haven't received response.that was when we talked on phone.
Old 08-03-2011, 11:55 AM
  #5501
filetto's Avatar
Durango have brought along a new steering system, the first samples of which only arriving on Monday giving drivers no time to test the new unit prior to the event. Featuring a new steering plate, it allows the adjustment of the ackermann with the addition of 2 extra mounting holes to give the car more progressive steering, its current configuration being very direct and nonadjustable. Expected to come fitted with bearings when its released in the coming months, the new plate also allows the adjustment of bump steer through the use of spacers.
http://events.redrc.net/wp-content/u...goSteering.jpg
Fonte redrc
filetto is offline
Old 08-04-2011, 04:28 PM
  #5502
Kolunatic's Avatar
Thumbs up
Just installed the new m2c flywheel and clutch. It's a work of art! Bolts right in, no problems!
Also installed the m2c throttle arm, another fine work of machining!
Gotta get some track time in a bad way
Thanks for the fine craftsmanship m2c!
Old 08-04-2011, 10:24 PM
  #5503
Trader Rating: 66 (100%+)
Just picked up a new DNX408 and looking for a good starting setup. I run on a med to sometimes high bite track that is fairly smooth with a few blow outs. I would like something somewhat easy to drive but with alot of off-throttle steering as my driving style I like to roll the corners and then power out. Any suggestions?
Gwoodrc is offline
Old 08-04-2011, 10:43 PM
  #5504
Jerad8's Avatar
Trader Rating: 114 (100%+)
Hey guys, I got a new center diff and center diff mount/brake assembely listed.
http://www.rctech.net/forum/r-c-item...408-parts.html
Jerad8 is offline
Old 08-05-2011, 12:49 AM
  #5505
Kolunatic's Avatar
Talking
Sounds close to the track I run. I have mine setup on soft side and it was hooked up.grey springs all around,Losi 35 all around,stock pistons,full rebound,front camber link on tower inside 2 up, rear camber on tower inside bottom,0 hubs forward,2mm rear sway,2.5mm front sway,4mm preload on springs.-3 toe,-3 camber all around on shotgun softs tires. Got 3rd place.
