Durango DNX408 - Fast enough to win the World Title. >
Old 05-25-2011, 04:36 PM
  #4771
Kolunatic's Avatar
No brake fade here, I need to back off mine a little.
If you put the 2mm beveled washers on brake posts with about 1mm spacing to pad, and your linkage adjusted right, it'll stop on a dime.
Kolunatic is offline
Old 05-25-2011, 05:12 PM
  #4772
Frank L's Avatar
Trader Rating: 148 (100%+)
Ya I have had other issues but never with brakes on this car. Just make sure you set your end point correctly, the action on the brake mechanism is very short and the F/R adjustment is very sensitive.
Frank L is offline
Old 05-25-2011, 07:25 PM
  #4773
hard4nitro's Avatar
Trader Rating: 57 (100%+)
Originally Posted by JoeC
I wanted to thank Frank L for mentioning something About Nankin Hobbies a few pages back. I gave them a call today to check on ordering a os speed piston, rod, and sleeve and the gentelman answering the phone was very nice and got me all fixed up and gave me a good deal as well. Good customer service is hard to find nowadays so I am sure I will be ordering from them again in the future.
On a side note is anyone experencing brake fade and if so has anyone tried different pads and disc to correct it? If so, which ones are you using?
+1 on NANKINHOBBY.COM
Mike is awesome he will give you the best deal possible guarantee!!!!
Ashton
aka Big Worm
hard4nitro is offline
Old 05-25-2011, 08:32 PM
  #4774
Any idea where I can get a wing mount in the US? Something so simple/cheap is been out of stock for probably 2 months. I cant even explain to you guys how irritated I am with this issue. Can someone from Durango please chime in with possible delivery date?
For guys with different brands still around could you please see if any other brand fits. I dont care how many holes i have to drill in the shock tower as long as I can make it work. Durango wing mount is very weak and I wouldn't mind switching to something stronger anyways.
Thanks for the help
Norbert50p is offline
Old 05-25-2011, 09:20 PM
  #4775
FMLinero's Avatar
Thanks for the help
http://cgi.ebay.com/TEAM-DURANGO-DNX...item4aab74597c
FMLinero is offline
Old 05-25-2011, 10:07 PM
  #4776
Frank L's Avatar
Thanks for the help
Norbert the Durango wing fits on the agama mount. I have one you can try sat if you guys are coming to CVR.
Frank L is offline
Old 05-26-2011, 01:25 AM
  #4777
Default little mod for the support
Originally Posted by lewis666
hi there,
does anyone have problems with the throttle support twisting? mine seems to twist alot. i heard fioroni throttle/brake holder is quite good?
many thanks
lewis
hi, I had a similar issue but mine was completly unscrewed just put two longer screw with two nylstop 3mm on the top. it will made safe and limit the flex a lot.
regards
Schnurf is offline
Old 05-26-2011, 05:20 AM
  #4778
lewis666's Avatar
regards
i will try that mod thanks. the screws holding it down dont seem to get a good hold i will look into that. the thread might be threaded and the screws aren't tightening. have you got a picture?
thanks
lewis
lewis666 is offline
Old 05-26-2011, 06:43 AM
  #4779
TeamDurango's Avatar
Thanks for the help
Really sorry about this - we've actually revised this part slightly and it should be available very soon.
TeamDurango is offline
Old 05-26-2011, 08:02 AM
  #4780
pword's Avatar
Trader Rating: 30 (100%+)
and when is the modified tank coming out?
pword is offline
Old 05-26-2011, 08:59 AM
  #4781
Default Mod
thanks
lewis
Schnurf is offline
Old 05-26-2011, 01:51 PM
  #4782
dark's Avatar
the mid CVD is not very "serious about racing" in this car, infact, I have to change the mid CVD (rear) in each race because the car is blocked on rear axle.............. I have worn 2 cvd in the last race (track with more grip)
I want to know what Team durango doing, because this is a serious problem
I do not understand why no one complains wear of CVD mid (rear) on this forum, you're losing many customers for these problems, and think instead support wing .......... wrong policy, your customers can not wait for December to get these parts, absurd industrial policy!
What should I do? Actually, I have to spend 20 euros for each race for mid CVD, it seems right?
you lose any more time and dnx408 will be labeled with "fragile car", this is world of race !
in 7 months to release 2 shock diaphram ... very good job, lol!
you already have all the pictures of my broken parts submitted by Italian Distributor, is an encyclopedia ahahhaha
guys stop defend the Durango work, it's time to reclaim
sorry But I'm angry with Durango, with me the few italian customers remaining !
dark is offline
Old 05-26-2011, 02:34 PM
  #4783
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
The Losi wing mount fits but holds the wing about 3/8" higher
TIX is offline
Old 05-26-2011, 03:52 PM
  #4784
Trader Rating: 19 (100%+)
I find it hard to believe that you go through parts like that. If so maybe a different car is what you need? This is supposed to be a fun hobby.........
Pin2Win is offline
Old 05-26-2011, 06:56 PM
  #4785
FastPete's Avatar
Trader Rating: 44 (100%+)
I have never changed mine yet.....three races, and many practice days.
FastPete is offline
