Durango DNX408 - Fast enough to win the World Title. >
Old 04-18-2011, 11:29 PM
  #4036
Kolunatic's Avatar
4mm not pm, stupid iPhone!
Kolunatic is offline
Old 04-19-2011, 03:10 AM
  #4037
Kolunatic's Avatar
I don't even use heat tape anymore because it's not a heat issue. I put tape on tank and that's it.
Traction..... I've got to keep from riding wheelies on one part of local track! That's with a 3 port!
Old 04-19-2011, 03:12 AM
  #4038
Originally Posted by Spads11
Can someone post a pic of how they have their fuel filter setup? I'm out of ideas trying to fit my body over mine on the left side . It jacks my body up on the left somewhat, making my fuel filler cap rub on the cutout side of the body. I'm trying to avoid making the fuel filling window larger to prevent.
If you get a get a couple of spare servo saver setups you will end up with some extra servo mounts. I used the extra rear-front servo mounts (the extended ones with mounting hole on top for the radio box) to mount the steering servo. I then screwed a strip of thick plastic between the upper holes and mounted the fuel filter to this. You could mount a splash shield to the mounts instead if you prefer....or even a splash shield and mount the fuel filter to it too...
Haven't measured capacity with routing/filter yet though....
Attached Thumbnails Durango DNX408 - Fast enough to win the World Title.-img00061-20110418-2021.jpg   Durango DNX408 - Fast enough to win the World Title.-img00059-20110418-1945.jpg
Jaf1977 is offline
Old 04-19-2011, 03:14 AM
  #4039
Kolunatic's Avatar
Originally Posted by Schnurf
Hi, cant aligned my new OS speed .19. I have try all I can. Do you think I may race like this?
You can run but I'd trim more off rear brace. You can remove the front screw from brace which will let you trim more off since you're left with two screws side by side.
Old 04-19-2011, 03:15 AM
  #4040
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 149 (100%+)
Should be fine. Unfortunately I have a similar issue w/ my new M2C adj. clutch setup. Moves the clutchbell quite a bit forward... As long as you have at least half of the gears touching it should be fine, granted it will wear quicker. But there is no other way around it shy of notching out the chassis holes and moving everything back a bit.
chedda bob is offline
Old 04-19-2011, 03:19 AM
  #4041
chedda bob's Avatar
Originally Posted by Kolunatic
Believe me, it's not a heat problem. The kit had some servo spacers which I had used on steering servo to raise it off servo plate. It's shown in the manual. I put 3pm locknuts with 15 mm bolts which raised servo about 4pm, cut the bottom off rx box now servo is up into box with rx sitting on it.haven't had a problem since in this Texas heat.
And I assure you it IS a heat problem... Depending on the servo used, it may sit too close to the motor (like my JR 8917hv's did). I killed 2 of them in the exact same manner as mentioned... Cutting out, would work, then do it again. I put in a Savox 1268 I believe? (too early to go look) which has an overall MUCH smaller case. 3 racedays/ practice days down and not a single problem. Where as I killed the 2 JR's in the same day....
Old 04-19-2011, 03:26 AM
  #4042
Kolunatic's Avatar
I fried an xp 1015 first. Then a savox 1257, both with dbl sided tape and heat tape on bottom and on back facing engine. Since I raised servo with 3mm locknuts and cut the rx box to the tab that holds wires, I haven't had a problem.
Old 04-19-2011, 03:29 AM
  #4043
I've been running 2 x ACE DS1015 (same as XPs) since I got the car and haven't had a problem so far. I have put 1.5mm spacers between the servo and the mounting blocks though as they are deeper than most other servos (so spaces them away from the centre line slightly).
Jaf1977 is offline
Old 04-19-2011, 03:31 AM
  #4044
Kolunatic's Avatar
Any advice on grabbing wheelies now and then other than letting off throttle?
Old 04-19-2011, 03:35 AM
  #4045
Kolunatic's Avatar
I went ahead and raised the steering servo the same. I like the gap and better for cleaning and keeps fuel off it.
Old 04-19-2011, 06:08 AM
  #4046
R/C Tech Elite Member
Spads11's Avatar
Trader Rating: 33 (100%+)
Thumbs up
Nice setup! Thanks for the ideas.
Spads11 is offline
Old 04-19-2011, 06:35 AM
  #4047
Any chance you could post a picture of this please?
ratjayfala is offline
Old 04-19-2011, 07:10 AM
  #4048
Default .19
I have os .19 in mine and fits fine! Are you using stock clutch bell if so it will work.
Iggy 102 is offline
Old 04-19-2011, 07:14 AM
  #4049
Frank L's Avatar
Trader Rating: 148 (100%+)
I ended up using a Losi collet because it's shorter And it's closer
Frank L is offline
Old 04-19-2011, 07:57 AM
  #4050
Default clutch
hi, no I am running BBF model type, i try the original durango clutch, but same, trying Fioroni, the same.
I need 26,5 diameter inside the clutch with zero offset
thanks!
Schnurf is offline
