Durango DNX408 - Fast enough to win the World Title. >
Old 04-18-2011, 11:15 AM
  #4021
Sarky's Avatar
I personally use the ascendancy RC clutch on my DNX408. I use the steel flywheel version 34mm and it fits perfectly!! THe only thing you have to do, is milling the chassis with a dremel to make the hole a little bit bigger and it's fine!
Sarky is offline
Old 04-18-2011, 11:22 AM
  #4022
R/C Tech Elite Member
Spads11's Avatar
Trader Rating: 33 (100%+)
Talking Fuel Filter fitting
Can someone post a pic of how they have their fuel filter setup? I'm out of ideas trying to fit my body over mine on the left side . It jacks my body up on the left somewhat, making my fuel filler cap rub on the cutout side of the body. I'm trying to avoid making the fuel filling window larger to prevent.
Spads11 is offline
Old 04-18-2011, 11:26 AM
  #4023
kcrisalli's Avatar
Trader Rating: 36 (100%+)
I am wanting to try and run some 1.2 shock pistons, does anybody know which ones fit, or if you can buy blank ones from anywhere?
kcrisalli is offline
Old 04-18-2011, 11:31 AM
  #4024
teeforb's Avatar
Trader Rating: 94 (100%+)
why the 34mm over the 36? Esp if you have to do mods using the 34..
teeforb is offline
Old 04-18-2011, 12:33 PM
  #4025
Frank L's Avatar
Trader Rating: 148 (100%+)
Heres what I ended up with as for fuel filters. It does hit the body a little bit but theres not much room for them. BTW the tank is seriously under capacity with the setup in the pic I measured it out to 123.5cc. Hope this helps.
Frank L is offline
Old 04-18-2011, 12:42 PM
  #4026
Spads11's Avatar
It helps immensely! I routed on the other side and it just doesn't work. I saw a guy running the splash guard at my club race this last weekend and am thinking of getting one, if not just to connect the filter to it. I haven't measured my capacity yet, but tried to get a one stop 20min main and flamed at 9:30 . No guts, no glory and I'm surely not a pro! Thanks for the response
Spads11 is offline
Old 04-18-2011, 03:09 PM
  #4027
Frank L's Avatar
Thats what I was getting was 9:30 until I put in the fuel filters and now I can pit at 10 mins.
Btw I run the exhaust line around with the fuel line to make it longer. It was too short.
No guts no glory. Now there's a classic
Frank L is offline
Old 04-18-2011, 04:21 PM
  #4028
Kolunatic's Avatar
i ran over 10 minutes with a go 3 port,external filter
Kolunatic is offline
Old 04-18-2011, 05:14 PM
  #4029
Kolunatic's Avatar
thanks for the input reno.good luck at neobuggy!
Old 04-18-2011, 05:16 PM
  #4030
Kolunatic's Avatar
congrats ryan on a great weekend at norcal.good luck at neobuggy,
Team Durango!
Old 04-18-2011, 07:37 PM
  #4031
Losi #56 is the equivalant to 1.2 and they do work after enlarging the center hole
buggy_driver is offline
Old 04-18-2011, 07:45 PM
  #4032
Last weekend my throttle servo (7955) stopped responding at the end of a 5 min heat, so i put a brand new (1015) in it's place and two heats later it does the same thing. Both times as soon as i get to the car they start working again. So i believe they are getting too hot. Anyone else having this problem or know how to fix it? I do have some Losi heat tape on the part of the servo next to the engine, but I think it just needs some air running over it some how.
Old 04-18-2011, 08:02 PM
  #4033
Trader Rating: 56 (100%+)
Check your receiver, that channel may be faulty.
underway is offline
Old 04-18-2011, 11:19 PM
  #4034
Default Aligned clutch/central diff
Hi, cant aligned my new OS speed .19. I have try all I can. Do you think I may race like this?
Schnurf is offline
Old 04-18-2011, 11:26 PM
  #4035
Kolunatic's Avatar
Believe me, it's not a heat problem. The kit had some servo spacers which I had used on steering servo to raise it off servo plate. It's shown in the manual. I put 3pm locknuts with 15 mm bolts which raised servo about 4pm, cut the bottom off rx box now servo is up into box with rx sitting on it.haven't had a problem since in this Texas heat.
