Durango DNX408 - Fast enough to win the World Title. >
Old 12-10-2010, 11:28 AM
  #361
I put an Xray brake pad on the outside of the outer pads to take up free play in the brake travel. These were 1.5mm thick and seem to do the job nicely...
Adjusting the brake bias is done by adjusting the length of the the linkage that attaches the front and rear brake cam levers.
When you talk about 'retainers' do you mean the plastic things that go over the outdrives? If so, are they are supposed to locate inside the diff/pinion 'shell'? I just popped mine over the outdrives once the shell was complete and they spin freely and just protect the bearings from some of the crud....I could be wrong and may have built mine wrong!
In terms of the drivetrain being tight, did you install all the axle/hex shims? If you do...it is very tight. I only used some of the shims and will re-shim after a race or two (if/when needed). Other than the shims between the spur gear and centre diff bearing and between the centre diff cup and other centre diff bearing, I don't have any shims in the diff and all seems nice and smooth (assuming I haven't cocked up the build regarding the 'retainers'/plastic outdrive covers!
If you are having problems meshing your engine...check the backplate isn't hitting the rear chassis brace. I had to shave my rear brace a bit to get my Nitrotec to fit/mesh better...
Has anyone had any experience with Vibra-tite (link)? Just wondered if it may be a better solution rather than keep re-applying threadlock...
Jaf1977 is offline
Old 12-10-2010, 11:37 AM
  #362
CaLaBeR's Avatar
Adjusting the brake bias is done by adjusting the length of the the linkage that attaches to the front and rear brake cam levers.
No that was my mistake, I went and looked on the link from max bashing and the guys with there complete kits had theres on the outside aswell so I am assuming this is the proper way to have them.
CaLaBeR is offline
Old 12-10-2010, 11:53 AM
  #363
carkingaz's Avatar
Trader Rating: 19 (100%+)
Good stuff Jaf,
The plastic outdrive covers just slip on and off the outdrives not into the diff housing..
One of the rear bolts on the back of my motor weas hitting the rear brace.I also had the dremel a small piece of the rear plastic chassi brace for my plus 4 to mesh properly to the center diff.
carkingaz is offline
Old 12-10-2010, 12:29 PM
  #364
Signal151's Avatar
I just ordered a 408 from A-main along with a Savox 1256TG servo for the throttle! (I have a NIB Hitec 7955TH for steering.) I'm usually not an early adopter but this car looks so good I just couldn't resist! I hope it's worth it...
Signal151 is offline
Old 12-10-2010, 12:42 PM
  #365
bcquick's Avatar
adjusting break bias is nearly imposible with out removing the transponder mount first. and when you do get a wrench on it both sides will just pop off the balls when you try to turn it .
i am sure we will come up with a better solution for this problem, maybe a thumb wheel if there is room, and running the threaded rod in and out of the ball cups several times to loosen them up a bit
bcquick is offline
Old 12-10-2010, 12:44 PM
  #366
Or just pop it off, adjust and put it back on!
Jaf1977 is offline
Old 12-10-2010, 02:08 PM
  #367
Registered User
Will you guys please post some pics of your new Durango DNX408's. I am interested in seeing some good pics of this Buggy. Thanks
Beagle32 is offline
Old 12-10-2010, 02:31 PM
  #368
Here you can find some pictures of mine I haven't build the brake and radio plate because I'm going to convert my 408 in brushless
http://www.rc-monster.it/public/foru...p=70882#p70882
sirio76 is offline
Old 12-10-2010, 02:37 PM
  #369
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
wheres the cheapest place to get the 408 from?
TIX is offline
Old 12-10-2010, 02:51 PM
  #370
jspurgin's Avatar
Trader Rating: 216 (100%+)
Well my 408 should be here in about 30 mins.. Anyone having trouble with the build yet??
jspurgin is offline
Old 12-10-2010, 02:59 PM
  #371
CaLaBeR's Avatar
Nothing really hard about building it, just take your time putting it together and follow the instructions and you will be good to go!
CaLaBeR is offline
Old 12-10-2010, 03:04 PM
  #372
Only a little trouble with servosave.
sirio76 is offline
Old 12-10-2010, 03:05 PM
  #373
jspurgin's Avatar
Thanks guy's.. I may have to pull an all-nighter on this one.. lol
jspurgin is offline
Old 12-10-2010, 03:28 PM
  #374
CaLaBeR's Avatar
What trouble did you have with the servo saver?
CaLaBeR is offline
Old 12-10-2010, 03:29 PM
  #375
Team Tekin
Randy_Pike's Avatar
Tekin would like to welcome Team Durangos Ryan Lutz to the team:
http://teamtekin.blogspot.com/2010/1...ryan-lutz.html
Attached Thumbnails Durango DNX408 - Fast enough to win the World Title.-tekin_rlutz.jpg
Randy_Pike is offline
