Durango DNX408 - Fast enough to win the World Title. >
Old 12-10-2010, 02:00 AM
  #346
shanef's Avatar
Trader Rating: 38 (100%+)
Originally Posted by TeamDurango
Sorry I don't understand the question
Ti screw set, looks like we need to make one then,
By looking at how many screws are actually used in the kit, it would be greatly beneficial of a Ti screw kit i reckon.
shanef is offline
Old 12-10-2010, 02:09 AM
  #347
Default screws
12x SH M3x12
4x CS M4x12
4x CS M3x6
5x CS M3x12
3x CS M3x14
8x CS M3x10+
5x CS M3x8
2x CS M3x8
1x CS M3x20
3x SH M2.5x6mm
4x SH M3x8
8x SH M3x8
2x SH M3x8
4x SH M3x10
4x SH M3x10
2x SH M3x10
8x SHM3x12
6x SH M3x16
5x SH M3x16
5x BH M3x5
2x BH M3x14
18x BH M3x6
9x BH M3x8
13x BH M3x18
6x BH M3x16
2x BH M3x20
2x BH M3x22
2x BH M3x8
16x BH M3x10
2x BH M3x8
2x BH M3x18
4x BH M4x18
4x CS M2x5
1x TIE ROD 18MM
2x TIE ROD 48MM
2x TIE ROD 60MM
2x TIE ROD 64MM
total: 184 screws
1x tIE ROD 33mm 330108 x1
1x THROTTLE TIE ROD 54.7mm
310071 x1
1x BRAKE TIE ROD 74.7mm
310070 x1
Schnurf is offline
Old 12-10-2010, 02:18 AM
  #348
TeamDurango's Avatar
14/48T is good for big tracks like Pattaya, 13/48 is good for normal sized tracks.
"- how many screws to remove in order to get the whole radio try of the chassis ?" - Its possible to remove the radio tray with only 5 screws, but its easier if you also remove the side guard (4 more screws) OR the rear axle (6 more screws)
"- what it the best procedure to remove the engine, for the throttle linkage ?" - I'm not sure what you mean sorry.
TeamDurango is offline
Old 12-10-2010, 04:23 AM
  #349
As promised
We will be working on multi-lingual manuals but I am sorry we don't have an Italian version at the moment, scusa.
Ciao
Hi,
When the option spring set and sway bar set will be available?
mazzinga is offline
Old 12-10-2010, 05:25 AM
  #350
Originally Posted by mazzinga
Hi,
they ship in a week
Old 12-10-2010, 07:14 AM
  #351
when you want to remove the engine from the chassis you have to free the throttle linkage somewhere. So my question was : how can we do it easily ? (for instance on the mbx6 i used to simply remove the 1 screw of the linkage on the servo horn)
Thanks for the other answers.
charlymbx5 is offline
Old 12-10-2010, 07:46 AM
  #352
Its easy, you just pop the ball joint off the bell crank or the carb.
Old 12-10-2010, 08:18 AM
  #353
carkingaz's Avatar
Trader Rating: 19 (100%+)
Hello, I took my buggy out for some shake down laps last night @ The Nitro Pit. I am having trouble with the brakes i cant get enough thrown on the center diff linkage. It seems that there is to much of a gap between the calipers and the brake disk.
Also what is the best way to adjust brake bias?
On a positive note i have raced many cars in my 20 + years of racing and this is the best accelerating and jumping car that i have raced!
Set up so far is box stock 7-7-3 diffs losi 40 front 35 rear full drop ( this car has a ton of it) Temp outside was about 60deg. Will try 45f ,
40r next..
Car has amazing control rear is locked in and the steering going in and out of turns is second to none..
Please advise on my braking issues
Thx Todd Jonas
Owner and founder of The Nitro Pit
carkingaz is offline
Old 12-10-2010, 08:24 AM
  #354
CaLaBeR's Avatar
Sorry, I tried typing that message from my iphone and it did not work out the greatest. I got it all figured out though. This is a very high quality kit, lots of fun to build!
CaLaBeR is offline
Old 12-10-2010, 08:26 AM
  #355
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default you need to put 1mm spacers on the pin that holds the calipers
This will close up the gap from the factory.
TonyWest is offline
Old 12-10-2010, 08:32 AM
  #356
I've just build my 408, great car!!! my only concern is about the differential gear mesh, it's supposed to be that tight? the car doesn't spin free at all...are you having the same problem?
sirio76 is offline
Old 12-10-2010, 08:34 AM
  #357
carkingaz's Avatar
Thx Tony, i did that when i built the diff but it still is not enough..I will try two 1mm spacers and see how that works? Just thought maybe i did something wrong...
Old 12-10-2010, 08:35 AM
  #358
carkingaz's Avatar
All that loosened up after about three tanks fuel.. Then people were commenting how free the car felt. Also i did not use the shim on the bevel gear side.
Make sure you use the spacers for the brakes as you build this will save you time later.
How it goes is the bolt two 1mm spacers steel caliper spring brake disk the back side caliper ( I used some left over spacers from my sc-10)
Hope this helps..
Old 12-10-2010, 08:40 AM
  #359
CaLaBeR's Avatar
Thanks I got it fixed now.
CaLaBeR is offline
Old 12-10-2010, 08:47 AM
  #360
Hope this helps..
TNX
sirio76 is offline
