Durango DNX408 - Fast enough to win the World Title. >
Old 03-18-2011, 10:54 AM
  #3361
sorry for that clear words, BUT :
stop that "mod" dicussion. until itīs an official change/update/option or whatever this mod is theoritical bul*s**t !!!
team durango & their proīs are testinīa lot, but prototype testing at first means nothing to me. theyīre all testin prototype parts, that doesnīt mean that the car has a problem/issue, right !?
my suggestion :
JUST ENJOY THIS CAR, itīs already awesome.
... itīs all about the driver anyway.
jusīmy 0,02
gt racing is offline
Old 03-18-2011, 11:06 AM
  #3362
Default Mod
Sorry sir :-)
If I put 2mm to lift the total support is it the same result ? ( where you have the red line
Schnurf is offline
Old 03-18-2011, 11:11 AM
  #3363
mlbright's Avatar
I just used some washers that I had, stacked them up until I got the desired height of 2mm. The Bulkheads stay where they are, it only the arm holders for the rear only that get raised. I will post up some pics after a race this weekend. Lutz has the setup on his page, it will show you everything else you need to know.
Originally Posted by Bernarossi
How did you do this mod? With washers or a custom 2mm plate? Also is it just the Bulkhead that is raised 2mm and everything else stays? At Nitro Challenge I saw Billy Fischer running this mod and he also ran shorter camber links.
mlbright is offline
Old 03-18-2011, 11:13 AM
  #3364
mlbright's Avatar
In your pic you are raising the bulkheads, they stay where they are, you are only shimming the rear arm holders.
Originally Posted by Schnurf
Sorry sir :-)
mlbright is offline
Old 03-18-2011, 11:29 AM
  #3365
mlbright's Avatar
mlbright is offline
Old 03-18-2011, 11:41 AM
  #3366
Default Nice
NICE SHOOT SIR! thanks a lot, it s clear!:-)
Originally Posted by mlbright
Schnurf is offline
Old 03-18-2011, 12:26 PM
  #3367
mlbright's Avatar
No problem, anytime I can help. Remember guys, do this mod at your own risk and make sure to take your time. I'll be doing more testing this weekend.
mlbright is offline
Old 03-18-2011, 12:29 PM
  #3368
Default Roll axis
Here is a pic from 1/1 scale very speaking
Schnurf is offline
Old 03-18-2011, 12:31 PM
  #3369
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Me and my buddy have been working on setups for this car and today it was on most steering and traction stable car i have ever drove! period
Ultraspeed84 is offline
Old 03-18-2011, 02:15 PM
  #3370
Frank L's Avatar
Trader Rating: 148 (100%+)
Ok so care to share your setup??
Frank L is offline
Old 03-18-2011, 02:39 PM
  #3371
Noticed that Travis Amezcua is running for Durango at the Cactus race. Is he going to be running the nitro cars aswell?
Stefan Millay is offline
Old 03-18-2011, 03:24 PM
  #3372
This arm holder mod seems to be "the Shit". So, is there any drawbacks with it that will make me regret it later on a certain type of track? or is it just to hack away?
Martin.S is offline
Old 03-18-2011, 03:35 PM
  #3373
I will get a setup posted up later tonight guys!
Old 03-18-2011, 04:04 PM
  #3374
asmazure's Avatar
Raising or lowering the roll center using the rear arm mounts is a common adjustment for touring cars. I have adjusted this on my TC6 and it makes a huge difference but it is an adjustment just like any other that sometimes it is good for one track and sometimes not for another.Moving the arm mounts up 2mm is just raising the rear roll center,and that will increase rear traction. its a good adjustment in my opinion.But if you have not moved your inner camber link on the tower to the lowest position i would try that first.
asmazure is offline
Old 03-18-2011, 04:15 PM
  #3375
kwilke's Avatar
Trader Rating: 172 (100%+)
here is the set up that worked really well today
front diff 5000
front shocks middle on tower out on arm
front shock oil 1.4 piston 37.5 wt oil black springs
front camber link in #4 on tower
front camber -1
droop 106 ride height 27mm
14 degree hub
center diff 5000
rear diff 4000
rear shocks middle on tower out on arm
rear shocks 1.4 piston 40 wt oil
grey springs
rear camber -2
2 degrees anti squat
3 degrees toe
rear droop 116
ride height 29mm
zero degree hub
wheelbase on hub in the middle
camber link #5 on tower #2 on hub
kwilke is offline
