Durango DNX408 - Fast enough to win the World Title. >
Old 03-08-2011, 02:49 PM
  #3121
I have a losi clutch in mine! `=<>=;
xe
maxflo777 is offline
Old 03-08-2011, 03:17 PM
  #3122
Frank L's Avatar
Trader Rating: 148 (100%+)
xe
What mods did you have to do.
Frank L is offline
Old 03-08-2011, 04:28 PM
  #3123
didrace's Avatar
Guys is durango going to do any critical changes to the next production of the 408?
How do you guys find the car?
What changes does it need?
didrace is offline
Old 03-08-2011, 05:20 PM
  #3124
Frank L's Avatar
Im pretty much running it stock with a few spring and shock oil changes. I like the car it is very good to me. The only difficult thing was the throttle linkage but once its dialed its good. I am using mugen clutch springs the TD clutch springs are too stiff and the blue springs in the kit need to be tossed, IDK where they came from but they are all wrong.
Frank L is offline
Old 03-08-2011, 05:26 PM
  #3125
mmaattppllaayy's Avatar
Trader Rating: 35 (97%+)
Which mugen springs are you running the .9mm ones? also what color springs are you running
mmaattppllaayy is offline
  #3126
offroad dude's Avatar
Trader Rating: 31 (100%+)
Frank I mixed up my kit blue springs with the option blue springs how do i tell them apart
offroad dude is offline
Old 03-08-2011, 05:55 PM
  #3127
Anyone have a good starting point as far as setup goes for Psycho Nitro Blast? Track will be blown out in many areas, and there will for sure be large jumps
I do wish TD was back on here again keeping us informed
I'd like to know when the tank is going to be update with the splash gaurd?
When and if there is a Aluminum linkage mount coming to the throttle?
When are TD fluids coming out?
Is there a new rear chassis brace coming?
When is the optional clutch springs and clutch bells coming?
I really like the car, it would just be easier to make some decisions that need to be made.
Thank You for anyones answers or comments, again....I am not complaining.
SPEEDSKI is offline
Old 03-08-2011, 06:22 PM
  #3128
[IMG]://[/IMG]
All mods in the clutch.
Although I cut the engine base 1.0 mm to make up for the diference in radius (eg: flywheel diameter).
1- trim the clutch bell skirt
so it can go deeper in the flywheel
2- trim (chamfer) the clutch bell inner bearing lip
so it does not touch the flywheel when it goes deeper in
3- cut the flywheel nut outer face 1mm
again, so it allows the bell to go further deep
4- trim the flywheel so the inner bearing does not touch it
#4 is the only one that its a pita. You can do all but that one and assemble so you can see where it touches and then trimm where its marked
#1 & #2 can be cut easly and perfectly by putting the bell to spin on a crank in its own bearings while cutting it
#3 its fairly simple.
it'll take you a couple hrs but youll have it afterwards
Old 03-08-2011, 06:30 PM
  #3129
Originally Posted by Integra
Lol complaining about the Anodizing color now..... Common guys, Even the ever so popular Losi has a Faint difference in shock body's from 1 car to the next....Imo you better get over it as durango ain't gonna do Nothing for you....Its cosmetic.
Not interested in getting into an on-line debate with you on this. Based on the tone of your post you sound like your attempting to elicit some sort of argument from me. I think I'm totally within my rights as a consumer to question the finish of a product. I'm not complaining about this car. Like most others, I think it's a truly innovative car and, if you had read my post correctly, you would have noted that I said that this cosmetic issue would NOT have changed my decision to buy. I bought this car because it suited my style (yes I tested one before hand), I liked the innovation and the it looks fantastic to boot.
Are you a spokesman for Durango? How would know their response? Just another on-line keyboard jockey!
In conclusion, bite me!
ratjayfala is offline
Old 03-08-2011, 06:32 PM
  #3130
Old 03-08-2011, 06:34 PM
  #3131
lmfao
your such a
Alan D. is offline
Old 03-08-2011, 06:42 PM
  #3132
out of all the threads for all the cars i am following this one has the most whinny and complaining people I have ever seen in my life. Get it together people. Just drive the thing and ask questions about setups or give useful info. Go do your bitching and bickering elsewhere. Maybe I should start a new thread for all you guys where you can do that. STAY ON TOPIC
Old 03-08-2011, 06:48 PM
  #3133
Jms
Jms's Avatar
Has anybody tried smart diffs in the td.
I wonder how it would work.
Jms is offline
Old 03-08-2011, 06:51 PM
  #3134
The overall length of the diff needs to be the same measurement. If its the same length or within 1mm it could fit.
Old 03-08-2011, 06:54 PM
  #3135
Jms
Jms's Avatar
Is any body having problems with the wheel hob bearings
I had one race day in Them and they sound crunchy.
I just order some boca bearing set.
Jms is offline
