Durango DNX408 - Fast enough to win the World Title. >
Old 02-21-2011, 02:33 AM
  #2686
Originally Posted by packerbacker
It is good they both made the A Main for sure. I just think with a little more time they should wwin some of these races with the caliber of there driving. They are both excellent drivers and when they get the car tweaked right it should be awesome. Its new and hasnt had enough time. Love the car
Reno put on a great show during the B-main; just have a look at the lap times : http://www.liverc.com/view_result_fi...8B_Main%29.xml
Pretty fast and consistent, considering the rough track !
Seems that the start of the A-main had been quite difficult for him.
He got back to 5th before he had that 67 sec laptime.
On a side note it's seems that the lapcouting software is bugged for the best lap information : sometimes the opening lap is not supressed although it should be, thus this information is broken (for ex: G. Degani in the B-main).
charlymbx5 is offline
Old 02-21-2011, 03:19 AM
  #2687
TeamDurango's Avatar
Originally Posted by teeforb
Is part [TDR330069] updated on some kits, or are all of them thin for all kits?
This front-front hinge pin hanger is a running change in the kits - so newer DNX408's will come with the slightly thicker front pin brace.
TeamDurango is offline
Old 02-21-2011, 03:30 AM
  #2688
Kolunatic's Avatar
Default Thicker pin brace
Will the replacement parts be revised? The parts I ordered last week seem to be the thinner ones but I didn't get them. I'll go back to lhs and check again.
Kolunatic is offline
Old 02-21-2011, 06:18 AM
  #2689
Yay, a Lunsford kit. I almost bought the buckles seperately this week, but decided not to. Looks like I made the right choice. I'll wait until the kit is available in stores.
AMorgan is offline
Old 02-21-2011, 06:25 AM
  #2690
Default Springs set shocks
Anybody have try the new set for front and rear spring?
Need absolutly all the spring or just some of them?
Schnurf is offline
Old 02-21-2011, 06:30 AM
  #2691
jzemaxx's Avatar
I was just reading some s811 vs dnx408 threads. It seems that everyone likes the 811 over the 408 and many were saying how loose the 408 was on the track. Your thoughts?
I have both the 811 and 408. Right now nothing matches my 811 as far as being stable, turning and lap times. It is a full second faster then my losi 2.0 and mbx6 were. I am tinkering with lots of settings on the 408 now and seeing what changes will get mu times down. So far I have changed a good bit and the car is feeling real good. This weekend I'll have both cars on the clock. See what they will do pitted against each other with the changes.
jzemaxx is offline
Old 02-21-2011, 07:12 AM
  #2692
Frank L's Avatar
Trader Rating: 148 (100%+)
If you want to just buy a few springs I would getthe softer springs. Prob orange and grey.
Frank L is offline
Old 02-21-2011, 07:20 AM
  #2693
jzemaxx's Avatar
Correct I went down 1 softer in thr front then went to a losi green in the rear. Also drilled the 1.3 pistons to a larger bore. The suspension on this car is what is killing it. Response is a little to slow. Went to a larger piston holes and wow what a difference.
jzemaxx is offline
Old 02-21-2011, 07:21 AM
  #2694
The spares for the front-front hinge pin brace has only ever been the thicker revised part.
Old 02-21-2011, 08:32 AM
  #2695
teeforb's Avatar
Trader Rating: 94 (100%+)
What kind of track r u running on and what things have u changed?
teeforb is offline
Old 02-21-2011, 09:05 AM
  #2696
jzemaxx's Avatar
Right now, the shocks were drilled to 1.5mm also swapped to 5, 5, 2 diff oils. Next is swaybars......they are to stiff. The track is hard packed with loam on the side.
jzemaxx is offline
Old 02-21-2011, 09:15 AM
  #2697
teeforb's Avatar
What sway bars come with the car?
teeforb is offline
Old 02-21-2011, 10:22 AM
  #2698
teeforb's Avatar
What sizes are the holes in the shock piston that comes with the kit?
And the anti roll bar tuning set for the 408, what are the sizes for front and rear?
teeforb is offline
Old 02-21-2011, 10:27 AM
  #2699
teeforb's Avatar
What weight oil?
teeforb is offline
Old 02-21-2011, 10:43 AM
  #2700
Kolunatic's Avatar
Thanks for reply.
