Durango DNX408 - Fast enough to win the World Title. >
Old 01-17-2011, 02:25 AM
  #1696
Xchange's Avatar
Trader Rating: 10 (92%+)
how many people have diff leaking ?
and about broke the shaft, somebody try another sort of shaft ?
Xchange is offline
Old 01-17-2011, 04:48 AM
  #1697
I use LOSI gaskets, apply a bit of oil on them when assembling, and tighten opposing screws when tightening and haven't had a problem since.
First time round I lost lots of oil...
David1976 is offline
Old 01-17-2011, 06:16 AM
  #1698
Trader Rating: 21 (100%+)
I have yet to have a dif leak but I do sand the face before I build them
O'donnell racer is offline
Old 01-17-2011, 06:33 AM
  #1699
packerbacker's Avatar
That is a little thin but i would guess they are going to handle the issue for sure
packerbacker is offline
Old 01-17-2011, 06:58 AM
  #1700
Kalgard Racing's Avatar
Originally Posted by TrickyMick
Looks exactly like my Front Center Drive Shaft, that let go friday.
Make sure when you build the shafts and CVD's that they are bind free.
My diffs do not leak, make sure you DO NOT over fill!!
Kalgard Racing is offline
Old 01-17-2011, 07:14 AM
  #1701
Trader Rating: 18 (100%+)
Mine use to leak but not any more. I think the orings swelled up a little and sealed. Give them some time.
infanterene is offline
Old 01-17-2011, 09:36 AM
  #1702
Xchange's Avatar
Thanks, good to know, the Losi Gasket is a replacement without mod?
Xchange is offline
Old 01-17-2011, 10:28 AM
  #1703
Can someone tell me what size turnbuckle wrench I need for the 408?
buggy_driver is offline
Old 01-17-2011, 11:03 AM
  #1704
5mm
Old 01-17-2011, 11:06 AM
  #1705
rc ace's Avatar
you need a 5mm, i use a lundsford 1/8 scale wrench works great
rc ace is offline
Old 01-17-2011, 11:22 AM
  #1706
Frank L's Avatar
Trader Rating: 148 (100%+)
4mm steering links and 5mm tie rods
Frank L is offline
Old 01-17-2011, 12:03 PM
  #1707
Signal151's Avatar
Only my center diff leaked a little. I pulled it apart and reseated the housing to the spur then retightened the screws in the standard cross-pattern. No more leaking. I think I didn't get it quite seated right the first time.
Now none of my diffs leak. No sanding, no green slime, no Losi o-rings.
Signal151 is offline
Old 01-17-2011, 12:28 PM
  #1708
rc ace's Avatar
what are the benifits of running this part?what does it do?is anyone using it?
Team Durango Exhaust Manifold Support Set
rc ace is offline
Old 01-17-2011, 12:42 PM
  #1709
Frank L's Avatar
IDK I have seen it listed but It must be designed to keep the pipe off of the battery box. I guess. IDK
Frank L is offline
Old 01-17-2011, 03:16 PM
  #1710
rc ace's Avatar
is anyone using the Exhaust Manifold Support Set and have pics of it in use?
rc ace is offline
