Durango DNX408 - Fast enough to win the World Title. >
Old 01-16-2011, 12:59 PM
  #1666
Originally Posted by cartodinamo
mazzinga I use the mugen outer foam element, you have to cut it to fit the filter case, it's not perfect but I think itīs a better foam.
Thank you, you tried the inner too?
mazzinga is offline
Old 01-16-2011, 01:26 PM
  #1667
Kolunatic's Avatar
Originally Posted by RAlmeida
and my diffs leak......
There's nothing wrong with the diff's.
I take the diff cup and sand it on flat surface with 400 grit sandpaper lightly, green slimed both surfaces with stock gasket and fill to PROPER level.
The gears seem to like heavier weight fluids, IMO.
Kolunatic is offline
Old 01-16-2011, 01:27 PM
  #1668
Trader Rating: 18 (100%+)
Originally Posted by David1976
Mine weighs 3450g with Ace servo on throttle, KO on steering, Nova Plus4 Team, 053 pipe and Nimh RX battery.
Plus 4 is a heavy engine though...
That's probably a little less than a losi would weigh with the same combo. The 408 is not a heavy buggy
infanterene is offline
Old 01-16-2011, 01:41 PM
  #1669
Originally Posted by Frank L
It helps keep the rear in the rear hahaha. More planted.
Thanks Frank. I just got all the TD shock spring sets so can you post or PM your setup? We used the camber link on the RC8 for the same purpose and it worked well and at times really dialed the car in.
SPEEDSKI is offline
Old 01-16-2011, 02:03 PM
  #1670
Old 01-16-2011, 02:23 PM
  #1671
Frank L's Avatar
Trader Rating: 148 (100%+)
TD springs and sway bars should be here this week I ordered the kit so it took a little longer.
Heres what I ran yesterday.
Current Durango setup
Diffs 7-7-5
Front:
TD blue springs 32.5 wt 1.3 piston Middle tower – inner arm
Ride height 27
Droop 104mm
Camber link inner middle on tower middle on hub
Camber –2
Tow out 3 *
Sway bar 2.6
Rear: Green Losi springs (the green losi springs are softer than TD blue so I would try TD Green or Gray) 27.5 wt 1.3 piston middle tower – outer arm
Ride height 28
Droop 116mm
Hub middle position
Camber –3
3-3 toe plate
Sway bar 2.6
Clutch 13tooth TD shoes 1.0, .9, .9 (The .9 springs are mugen)
Frank L is offline
Old 01-16-2011, 02:38 PM
  #1672
Where are you getting the green rear spring from, I cannot still find them.
ironpeddler is offline
Old 01-16-2011, 02:47 PM
  #1673
Frank L's Avatar
I get all my stuff from Team Terribles. James is awesome at getting me TD parts.
But the green springs in my setup are losi springs.
Frank L is offline
Old 01-16-2011, 03:08 PM
  #1674
FMLinero's Avatar
L&A Parts House have them. (2) in stock
http://www.losipartshouse.com/servle...--Front/Detail
FMLinero is offline
Old 01-16-2011, 03:30 PM
  #1675
offroad dude's Avatar
Trader Rating: 31 (100%+)
Can some please help me with ny throttle linkage setup? Here is the problem. I can't seem to get my carb to close all the way when I let off the gas. It will close it I hit the brakes, I tried everything I can think of to fix this problem but with no reveal the same thing keeps happening. I even went set by set as stated on TD website
http://www.team-durango.com/blog/?p=2100
If anybody have any info on how to resolve this problem please let me know.
Thanks In Advance
offroad dude is offline
Old 01-16-2011, 03:35 PM
  #1676
Thanks In Advance
I used a stronger spring from a pen, instead of the black spring supplied with the linkage. In addition it's probably a good idea to put some sort of rubber band or throttle return spring on your carb.
Norbert50p is offline
Old 01-16-2011, 03:45 PM
  #1677
with the body being so tight on this buggy and with my engine/pipe combo i already burned a hole in it, despite using several layers of heat tape. Do you guys know if the bend is tighter on the Mugen manifolds and if it would fit? they are being advertised as compact and on the picture it looks like it might work. I'm also concerned that if the bend is too tight then the pipe will hit the tank.
This is what i have:
http://www.amainhobbies.com/product_...-Road-Manifold
This is what i'm thinking about buying:
http://www.amainhobbies.com/product_...Manifold-Mugen
Thanks for any insight...
Old 01-16-2011, 03:46 PM
  #1678
Thanks Norbert50p I will try that....
Old 01-16-2011, 04:00 PM
  #1679
Absolute Hobbyz has them and the complete spring kits F/R. Only $32 for all 8 spring sets.
I heard Premier was getting a TD parts order also.
SPEEDSKI is offline
Old 01-16-2011, 04:05 PM
  #1680
@ norbert :
hi, iīm using the 41029, it fits perfect on the dnx408
gt racing is offline
