Durango DNX408 - Fast enough to win the World Title. >
Old 01-10-2011, 09:23 AM
  #1501
packerbacker's Avatar
Premierehobbies is offering a great price on these kits for sure. Try them out and get one for the new season. I really like the looks of this buggy. Just need to get a splash gaurd made for the tank and the leaking diffs fixed up from what I see. All the other stuff is so minor it doesnt really count.
packerbacker is offline
Old 01-10-2011, 11:44 AM
  #1502
The diffs don't leak, for god's sake. I am the biggest noob and I put my diff's together fine with no leaking. Just because a couple people said they were leaking doesn't mean everyone is having that problem. Put some green slime on those gaskets and be done with it.
ironpeddler is offline
Old 01-10-2011, 11:51 AM
  #1503
merdith6's Avatar
Default Yep
Originally Posted by ironpeddler
The diffs don't leak, for god's sake. I am the biggest noob and I put my diff's together fine with no leaking. Just because a couple people said there were leaking doesn't mean everyone is having that problem. Put some green slime on those gaskets and be done with it.
The car needs extra attention during assembly. I found that simply rotating around to each screw in opposite directions and slowly tightening the diff helps to seat the two parts the best...Just a little extra time and patience...
merdith6 is offline
Old 01-10-2011, 01:12 PM
  #1504
apex-racing's Avatar
rebuit my diffs three times and still leaks from the o-ring side still think they should have a shim in there....
apex-racing is offline
Old 01-10-2011, 01:32 PM
  #1505
Integra's Avatar
Are you greasing the Oil grooves on the outdrives ?
Integra is offline
Old 01-10-2011, 04:20 PM
  #1506
i grease them with green slime idk? i notice it when it sits after i clean it......
Old 01-10-2011, 04:23 PM
  #1507
I've got 2+ gallons on mine and no diff leaks. I do grease the shafts and o-rings
rcmikel is offline
Old 01-10-2011, 04:55 PM
  #1508
merdith6's Avatar
Default Yep
I gotta agree with you there. The shim holds the oring in place a lot better. I tried putting one in from a mugen, it was too thick....
merdith6 is offline
Old 01-10-2011, 05:09 PM
  #1509
Trader Rating: 54 (100%+)
over filling leads to leaky diffs also
rkhess is offline
Old 01-10-2011, 05:24 PM
  #1510
hacker's Avatar
Trader Rating: 141 (100%+)
Default length of shocks
whats the length of the front & rear shocks?
I'm thinking of putting them on my dex410 as it will be a while until durango release the big bores for that car.
hacker is offline
Old 01-10-2011, 05:26 PM
  #1511
hogmansp's Avatar
Trader Rating: 47 (100%+)
They are way to big in diameter for that. They will not clear the front driveshaft and the springs offered are not nearly light enough.
hogmansp is offline
Old 01-10-2011, 05:33 PM
  #1512
lol! i tried the same thing yea just mushrooms the things
Old 01-10-2011, 05:37 PM
  #1513
Default Shock building
Can anyone explain whether the first part to go in the shock (TD230018) is a rubber o ring or plastic? Does it go inside the shock before the red o-ring or does it act as a seal on the red alu cap?
Pictures are more than welcome!
Regards
The rookie
Kebabkongen is offline
Old 01-10-2011, 05:58 PM
  #1514
Frank L's Avatar
Trader Rating: 148 (100%+)
Regards
The rookie
OK so you put the rubber o rings and spacers in the shock and then the thin black oring 230018 and then the the plastic washer, last the alum cap. The this plastic washer seems to only go in 1 way if it does not stick through the red alum cap dis-assemble the shock and flip it over. It needs to seat in the red alum cap properly. I hope this helps.
Frank L is offline
Old 01-10-2011, 06:16 PM
  #1515
But in the drawing the red o-ring are the second to go in, or do i have it all wrong?
As I read the drawing it is:
1. TD23008
2. red o-ring
3. black spacer
4. red o-ring
5. thin plastic washer
