offroad tire traction compound >
Old 10-30-2010, 11:10 AM
Losimoe's Avatar
Trader Rating: 18 (100%+)
Default offroad tire traction compound
just wandering if there's such a thing for offroad tire traction compound? i think using it would make the dirt stuck to the tire, but maybe using it for storage?
Losimoe is offline
Old 10-30-2010, 11:21 AM
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
People use some of the trinity stuff for indoor clay, but outside dirt its horrible for. Makes the tire feel like a banana peel.
This stuff:http://www.amainhobbies.com/product_...rce=google_ext
awdcameolsx is offline
Old 10-30-2010, 12:17 PM
I don't know what it is called in english, but directly translated from danish, I use something called "belt spray". It is designed for the belts in a real car, and it softens up the rubber. On asphalt tracks (like Furulund in Sweden) it really helps a lot. Just spray it on, and let it sit for hour or so. If you need more traction, you can let it sit longer. I have tried leaving tires overnight, and it completely sticks to the table. Almost impossible to get it off the table
Nilks is offline
Old 10-30-2010, 08:26 PM
RC-ZOMBIE's Avatar
Sticky-kicks best out there!
RC-ZOMBIE is offline
Old 10-30-2010, 09:41 PM
off road god's Avatar
Pro1RC is working on a traction additive/tire softener.
off road god is offline
Old 11-04-2010, 07:23 PM
Trader Rating: 26 (100%+)
Reino's Ragu and Marinade
ldp787 is offline
Old 11-04-2010, 07:26 PM
Trader Rating: 43 (100%+)
Yeah this is the best out there. Doesn't gunk up tires and lasts
mracer is offline
Old 11-04-2010, 08:32 PM
CJ Weaver's Avatar
+1
Best stuff in the world. You can use WD40 but it will destroy the surface of the track so I highly recommend NOT using it.
CJ Weaver is offline
Old 11-04-2010, 08:38 PM
rallyebmx's Avatar
Trader Rating: 21 (100%+)
+2 on the Ragu
It softens the tire, doesnt make it sticky
rallyebmx is offline
Old 11-04-2010, 08:54 PM
so its like a liquid you put on your tires before the race for more traction?
Cdj1091 is offline
Old 11-04-2010, 09:07 PM
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Buggy Grip II works very well on tacky clay. Anything other than a tacky clay surface, you're not gonna get any benefit from traction compounds.
JAMMINKRAZY is offline
Old 11-04-2010, 09:10 PM
rallyebmx's Avatar
Any time you feel like you could benefit from a bit softer tire spray it. Or he has marinade for overnight which softens them more
Old 11-04-2010, 10:08 PM
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Straight concentrated Simple Green.....
Racecrafter is offline
Old 11-04-2010, 10:12 PM
thats pretty cool stuff, didnt think they made it for off road cars, i knew they made it for the onroad ones
Cdj1091 is offline
Old 11-04-2010, 10:33 PM
+1, but honestly I would just buy a softer compound tire. I notice tire wear is better if you buy soft or super soft compound tires apposed to softening the tires with a chemical.
Although if you have a bunch of tires that are not soft enough then by all means have at it.
Alan D. is offline
