What lipo for losi 8ight t 2.0 receiver pack?
#32
I can say that the 900mAh packs will run a losi truggy with NO regulator and two Hitec 7955 for 30 minutes no problem. I have done that multiple times. But I have yet to push them to the 45 minute main. I still use my larger packs for them. But based on the milliamps that I put back in through the charger, I would say that they can do it, but you might be getting as low as 100 mA or less.
30 minutes main no problem. PM me if you have questions or think otherwise
45min unregulated would put it real close.....Too close imo.
No problemo.
#34
Try the Pro amps Life packs that can run for about 1.4 hours with 1450mah
they will be at the worlds and are the only packs that fit the losi
#35
1.4 hours, now that is the one I would buy if I ever had to run an enduro or a "worlds". In my case it will probably be the enduro.
#37
#38
#40
A Main Hobbies just released a new pack for the Losi:
http://www.amainhobbies.com/product_...-Balancer-Plug
#41
I'm running the Losi pack now but I used this pack last year and paid 29.99. They're only 19.99 now. Fits nicely in the 8ight too. http://www.commonsenserc.com/product...roducts_id=258
#42
This battery does not have undercharge protection and discharges at a max of 8c. The losi has undercharge protection and discharges at a max of 2c. This last little bit of info is straight from their websites. I'm questioning the 2c and 8c. Why the big difference? Any ideas? They are both rated at 14.8 watts and that's the part that I don't quite understand.
#43
Can you post which one you got
thank you
#44
Sure, the links I post are normally for Sales that are only up for 10 or so days, But here's some links for ya.
How many packs would you like ?
1 ?
http://cgi.ebay.com/7-4V-900mAh-LiPo...item2a0e5b830c
2 ?
http://cgi.ebay.com/2x7-4v-900mah-15...item4154421359
3 ?
http://cgi.ebay.com/3x-7-4v-900mAh-1...item4aaa6df2a9
4 ?
http://cgi.ebay.com/4x-7-4V-900mAh-L...item3366eb8385
5 ?
http://cgi.ebay.com/5-x-7-4V-25C-900...item4840184c8a
#45
I have been using the same packs Integra posted and they work awesome. They easily fit in a losi box with lots of room to spare. I actully had to add foam to keep it tight in there.
