truggy tires and foams???
Are you ever going to rotate your tires? Make sure you mark the rims so you dont inadvertantly put the hard foams on the left and soft on the right ... I would try both ways and see what you like better. That said its probably not a bad idea to use matching foams all around if you can help it.
Are foams really that expensive?? I think you are out of your mind running 2 different foams. Your car will react differently to them vs another set of tires with the same foam in each car. But i digress.
one pair is softer than the other, you have never felt foams that are differnt in softness? really? im not sure of the brand, they are not in package, got them from a buddy. firm/ hard, means the same to me.http://www.wheelspinmodels.co.uk/car...1-Pair__11580/ these are firm/hard
