What is a flameout? what do you do?
Engine flooded - your suppose to take the glow plug out and drain... I just drain through the pipe.
Your engine dying after a refuel or from loading up or countless other reasons. The ways to prevent it are just as countless. Like sucking an air bubble while refueling for example. To prevent, don't rev engine with tank open.
Flameout is when the engine cuts out and can come from lots of things. Bad tune, no fuel, flywheel is getting hit, old bad motor,....
I don't consider something getting stuck in the flywheel to be a flameout, but maybe my definition is different than others. Also i don't consider loading up to be a flameout, just poor engine tuning or leaving it idle too long without clearing out the engine by blipping the throttle. But thats me.
When it quits for no apparent good reason. Ie: vapor lock, predetonation, bad glow plug. Things that aren't easily identifiable as a reason for the engine to not run correctly and die. Many of which have to do with a bad tune, but may also be attributed to a loose and worn piston and sleeve or other engine components and poor sealing around the engine causing air leaks, bad bearings, etc.
A rock getting stuck in the flywheel is easy to spot, you say "oh theres the problem", remove the rock and fire it back up. If the engine gets flooded from idling you just put it back on the bump box and away you go.
Flameout: is when your engines stops all of a sudden...
I wanted to ask you what could be the reason of flameout after refueling. It happened to me three times in last main.
Every time i went out of pit the engine stopped working (and it was always after 4-6sec).
I'm using Losi gun but it happened also when refueling with fuel bottle.
It shouldn't be glow plugs fault and i don't have leaking fuel tubing or tank.
It looks like the engine has to much fuel at low rpms but it doesn't - it was running good and the temperature was ok.
I run JPX .21 that has 3 gallons on it (compression almost like in a new engine).
Do you have any ideas? It haven't happened to me before.
I hope you can understand something i wrote. English is not my language.
When you refuel your tank builds excess compression, then when you close the lid it compresses even more air into the tank which makes you run rich and can flood the engine. You could lean it out alittle more on the bottom end and/or blip the throttle a few times when refueling and just before taking off. Also when taking off be sure not to gun it, just blip it a few times to clear the excess fuel left in the crankcase and then you should be good to go.
