setup help?
hi there,
i am getting confused with my set up on my losi 8ight 1.5. my local track is very bumpy and usually dusty but last night it was damp and very sticky mud. does anyone have a good standard set up for bumpy tracks? has anyone tried the set up's on the losi website e.g truhe set up, and which one works best on bumpy tracks? many thanks lewis |
how does the diff react if I fill my diff up in my Losi:-
5-5-5 = ?? 5-7-3 = ?? 5-7-5 = ?? Similar to Lewis asking in similar condition. |
has anyone got any advise for me!
and king offroad look at the thread on rc setup video guide by squirrelod here is a link http://www.rctech.net/forum/nitro-of...quirrelod.html |
What is a 1.5?
keep the right height a little higher and it might help.
A 1.5 is like a losi 1.0 with a hole bunch of 2.0 parts? Correct me if im worng. |
I dont think no one is going to have a exact set up for one of these. You will have to try and play with the set up and see.
yes rcdude your right. it is all the important 2.0 parts that make a difference. e.g chassis, shock towers, hub and spindle carriers etc.
does anyone have a setup sheet or know a setup that is a good starting point on bumpy tracks? many thanks lewis |
Try starting with the basic 2.0 set up then tune from there, go up 1mm in front and rear on ride hight and a and droop to 97 front and 108 rear. Just a thought....
Originally Posted by mudboger07
(Post 7801204)
http://www.losi.com/Products/Support...rodID=LOSA0804 but which of these setup's would everyone recommend starting with on a bumpy track? many thanks lewis |
Originally Posted by lewis666
(Post 7801229)
i was thinking of starting with the truhe setup?
http://www.losi.com/Products/Support...rodID=LOSA0804 but which of these setup's would everyone recommend starting with on a bumpy track? many thanks lewis when i ran my 1.0 eight last year, the mike truhe setup worked pretty good on a bumpy track the only thing.. i changed was i used 25w in the rear and used toe out on the front. oh wait i used the his, nitro pit setup sorry but that worked good on a bumpy track. |
Originally Posted by tc5 man
(Post 7801241)
when i ran my 1.0 eight last year, the mike truhe setup worked pretty good on a bumpy track the only thing, i changed was i used 25w in the rear and used toe out on the front.
many thanks lewis |
(Post 7801249)
well i am currently running 2.0 shock towers so the setup positions are the same a 2.0. so anyone who is running a 2.0 on a bumpy track can i have a link or something?
many thanks lewis |
Adam Drakes Silver State Setup - that track was blow the F out.....
Originally Posted by king offroad
(Post 7800176)
Originally Posted by 8ight-racer
(Post 7801289)
Email Adam Drake for a setup for those type of conditions and he will send you one. I would look at Adam's setup for the Silver State race which was really loose and blown out. The only difference was adjustable pivots, #55 piston drilled out to a #54, 37.5wt in the front, and 7k in the center.
so the adam drake silver state setup will work well on bumpy tracks? many thanks lewis |
(Post 7801807)
what is adam drakes email, so i can ask him?
so the adam drake silver state setup will work well on bumpy tracks? many thanks lewis "Adam Drake" <[email protected]> he dosnt reply fast normally it takes about a week also you can go to losi.com and there forums have all the setups and a ask Drake section. |
Originally Posted by NitroXray80809
(Post 7801842)
copy and paste this in ur email to
"Adam Drake" <[email protected]> he dosnt reply fast normally it takes about a week also you can go to losi.com and there forums have all the setups and a ask Drake section. many thanks for the replies lewis |
| All times are GMT -7. It is currently 02:25 PM. |
