HELP! wheel hex set screw stripped >
Old 07-27-2010, 06:30 PM
jeff_ellis_9's Avatar
Default HELP! wheel hex set screw stripped
Was changing bearings in my wheel axles and the set screw that is inside the wheel hex is stripped! Its down in there and I can't get a dremel to it. How can I get it off?
jeff_ellis_9 is offline
Old 07-27-2010, 06:43 PM
Trader Rating: 47 (100%+)
You can try a Torx (star shaped) bit that is just a
hair bigger that the rounded out hex hole. Tap it
in with a small hammer and back the set-screw out.
A little heat may help soften any lock-tite on the threads
also.
rageworks is offline
Old 07-27-2010, 06:44 PM
Stubbs's Avatar
Trader Rating: 58 (100%+)
First, take a 1/16" drift pin punch and tap your hex pin out (don't worry, it's tight, but not so tight that you'll do any damage). Then you can get the hex out of the way and reach it with a hex wrench, EZ-out, Grab-It, LH Drill bit, whatever... I keep a LH drill bit in my box just for this. Pulls 'em right out.
It helps to heat the end of the axle up with a lighter too....makes the loc-tite soft.
Stubbs is offline
Old 07-27-2010, 06:45 PM
yea I have loc tite on it. I will try that
Old 07-27-2010, 06:49 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
i see u own a losi, this happens if you dont use a good quality driver.
Take the spindle off the car then The bigger pin that goes thru the axel(the pin that the set screw is holding in) you wanna punch that out. you will wanna put the hex in a vise or something to hold it still, it will take force but wont damage anything. once the pin is out take everything apart so all you have is the axle. heat the axel up right where the set screw is, heat it up really good. the set screw should come out . Ive had them round all the way out where hex driver were just spinning inside and with this method ive gotten it out.
losi_racer is offline
Old 07-27-2010, 06:57 PM
cordarrow's Avatar
Trader Rating: 17 (100%+)
NEVER...and I mean NEVER on this set screw.
It's not going anywhere anyway.....correct? Mechanically trapped in the first place...
cordarrow is offline
Old 07-27-2010, 07:00 PM
losi_racer's Avatar
no, that set screw isnt trapped, or do u mean the pin. i put a very very small dab of BLUE loctite on all my set screws, i use hudy/eds tips tho
Old 07-27-2010, 07:06 PM
I will try these and get back. thanks so far
Old 07-27-2010, 07:31 PM
cordarrow's Avatar
Uhhhhhhh.....yeah........fercryin'outloudyouguys.. ..
Old 07-28-2010, 12:28 AM
Jaz240's Avatar
Trader Rating: 52 (100%+)
the pin is only trapped if you never take your wheels off. pretty sure most of us change, or clean our tires. AE does not use set screws on their wheel hubs and those pins fall out all the time
Jaz240 is offline
Old 10-16-2014, 03:15 PM
TahoeDust's Avatar
I am going to bump this because it is good info. I have owned 8ights for about 5 years and just had this happen for the first time. I had not thought about using a punch to get the pin out. After it was out and the pressure was off the set hex it came out pretty easy.
TahoeDust is offline
Old 10-17-2014, 05:33 AM
Jerm13's Avatar
Trader Rating: 36 (100%+)
Yup. Had it happen to me a couple of times. I found a trick that works for me after the 3rd or 4th time.
I have found that if you take a dremmel with a cut-off wheel and put a flat spot on the hex pin where the set screw sits, you dont have to get gorilla tight with it. a dab of blue thread loc and install it nice and snug. It wont come loose untill you put a tool on it. And sometimes even a little heat helps break down the thread loc and makes it easier.
Jerm13 is offline
