-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Ninja .21jx bo1 (https://www.rctech.net/forum/nitro-off-road/419857-ninja-21jx-bo1.html)
ccordero85 07-25-2010 02:06 PM
Ninja .21jx bo1
What's up guys got a few questions...got my motor last yr broke it in performed good for a while. Like an idiot rode my buggy without a cover flipped it and broke off the high sped needle...went to my local hobby shop they said I could use a h/s needle of an os vz engine which they said was the same...So I did that worked fine noticed after a while it wouldn't keep an idle...front seal was leaking bad so ordered that up. Now my question is how could I check my piston and sleeve so I know it good before I put it back together and also how do I check my con rod I had heard they go bad on these motors. Thanks alot guys
Slider30250 07-25-2010 03:09 PM
Take your glow plug out and turn the motor over, if there is still some pinch at top dead center then the motor is fine, it's not quite broken in yet.
The con rod on the blue head V-Spec is the one that goes bad quick. One thing to consider is you idle might have dropped from the engine breaking in causing you tune to go rich. That would cause a leak at the front seal from the excess fuel.
ccordero85 07-25-2010 04:10 PM
Thanks for the advice man that's makes sense
