What plug for Novarossi N21BF??
Whats the best plug for the Nova N21BF? BESIDES Odonnell plugs. I would like a hot plug if its ok to run it in that motor.
Went to race today and couldn't get my buggy to run. Put in a brand new Odonnell 99 plug (what I been using) and still nothing. Tried tuning and still nothing. Motor seems to be fine, even ran good last time I raced it. But I havent got to run this motor very much. The buggy would seem to run OK if you leave the glo igniter on the plug, but as soon as I would take igniter away it would die almost immediately.
nova c6g is the best if you can get one or the purple odonnel sport plug
http://www.amainhobbies.com/index.ph...Plugs-Standard
it couldnt hurt to try and you might look at your fuel to
Don't know......
I would clean the inside of your engine really well with denatured alcohol, or motor spray, and oil it. If you want a slightly hotter plug I would try the mccoy mc-8, works great. Don't go too hot though or it will burn up faster, the plug....Check the fuel lines, tank, and clutch too.. it's always something simple.....
by oil try a quality assembly lube like cold fusion just to lube everything up before you reinstall if you still have problems give mark at powerhouse a call hes very helpful
Odonnel 99 is a medium plug. It's been a great plug for years.
http://www.odonnellracing.com/glowplugs/index.html
