grease to all the cvas joint and out drives?
How often do should you apply black grease to all the cvas joint and out drives? I have an RC8B.
I have to say "never".
Using a sticky lubricant turns it in to a grinding / polishing compound in pretty much no time at all. If you want to take care of your stuff, use dry lubrication. Teflon powder, paraffin, and wax-based stuff. B! |
i am a firm believer of using grafite powder like you put in door locks to free them up as it is dry and dirt wont stick to it as grease attracts dirt and dust real bad. i use this in combo with grease on my diffs for like a teflon grease and it works a treat.:batman:
KalGard clear chain kote. Goes on thin, and drys to a dry lube. Awesome stuff
I use Tri Flo, it is a dry film you can get it at any bicycle shop.
not to sound like an idiot. But what is a cva? And i always put mobil one on my outdrives, and universal joint shafts. Have i been doing it wrong all along?
CVA, universal joint, it's pretty much the same. It would be less likely to pick up dust and other grime with a dry surface lubricant. If it's sticky, it's bad.
B! |
I use grease if I have boots. If not then a dry lubricant. The Kalgard line of products rocks!
ok. is there anything i can get from the local hardware store that would be an equivalent? Been using mobil one and yea they are wearing pretty fast.
What about running them dry? |
Originally Posted by Mr B
(Post 7651189)
Using a sticky lubricant turns it in to a grinding / polishing compound in pretty much no time at all. If you want to take care of your stuff, use dry lubrication. Teflon powder, paraffin, and wax-based stuff. B! Wrong. Oiled sand and grit is a much better lubricant than dry sand and grit. That stuff just gets flung off and then your stuck with dry metal on metal. And the wax attacs as much grit as my oils. I tried Perdors, white lightning, some motorcycle stuff etc. I made my own selfcleaning lube, but it still looks nasty. I have't got it ready for market yet. Still have a few folks testing applications. It looks like oil but keeps a bike chain awesome clean. Works well in RC. Oddly, I designed it for niether! I lightly grease cvd pins and barrels. Then when they get coated with dirt I apply oil. You can allways bast it off with NC brakeclean, but I don't. If they are inside a rubber boot then I pack them full with grease. (The CVD, not the whole boot.) Disassemble all CVD's every 2-3 race days for cleaning, repair, pin replacement etc. Dusty conditions are the worst. |
Originally Posted by Zerodefect
(Post 7651915)
(Post 7651915)
(Post 7651915)
(Post 7651915)
(Post 7651915)
During the summer season i check up on the internals of the differentials every other week or so, and check for bent axles and play in the joins when the differentials are out. I've bent the left front axle twice, and twisted a rear axle once, (I blame someone else for using to much, to hard loctite on the wheel nut.) kept the good parts from the CVD's as spares, but so far haven't used them. Probably the only thing we whole heartedly agree on is that dusty conditions are the worst. B! |
so graphite powder would be ok? I can get a good bit of it for free.
(Post 7652289)
I have to admit, i don't race. I just bash. B! The dry lubes just don't stay where they need to be for long. And as long as your drives are wet enough the dirt adds very little wear. I have over 2 dozen rae days on my Xray 809 stock drives with only two dog bone pins replaced. No wear other than finish. Dreaux: I've had no luck with carbon powder at all. |
have you used this stuff just wondering what your opinions are it seems to work well and it stays where you put it.
http://www3.towerhobbies.com/cgi-bin...s699&search=Go |
There used to be a product called POWERKote WSX put out by Tech Line Coatings; has to be scrubbed into the metal (which is quite the PITA) but it works awesome. Good thing I still have an almost full bottle :sweat:
*edit* Actually, it's still around: http://www.techlinecoatingswebstore....bricant_2.html |
| All times are GMT -7. It is currently 11:10 PM. |
