looking for some nitro help
hey guys I have a dilema and would like some input from the masses.
I have a vspec motor that has gone bye bye. No compression left, I can get a speed piston/sleeve/rod nib for 140.00. Or a new werks b5 for 180.00. Or a Novarossi RX-21 P5XS just through break in. This is for a mugen mbx6t. Im not sure I want to get any more OS stuff because the vspec just doesnt seem to last too long. I have never used the werks or nova motors, and am wondering at how the nova listed would work in the truck? I have heard good things about the werks b5 in truck.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
keep the replies comming!!!!!!
just out of curiosity i would like to know where you can get a speed p/s/r brand new for $140?
crank pin is the problem with your vspec, piston sleeve and rod will not last long if the rod is sloppy on the crank.
If it where a Speed then it would be worth rebuilding because the crank pin will last and a re-pinch would do the trick. But if your crank pin is still perfect round a pinch is a great option on these motors because for $75 you can have the P/S re-pinched and new rod, clips, and wrist pin. The OS motors are great but at 4 gallons they need a pinch. A B5 is also a great option because it is a great motor with more then enough torque for the very light mbx6t. If you change motors you also gota factor in the price of a good pipe to run with that motor if you don't already have one. A "freshly broke in motor" to me sounds like someone screwed something up in the process and does not to run it.
Back to topic.. B5/2013 on Truggy best option, keep some bucks in your pocket, I forgot, no need to replace rod after brake in, also the support from Ron is second to none. Nova are very good engines but after both engines been ready to race you will spend less with werks.
Werks B5, I just ordered my 2nd one today from tower hobbies with a discount code on the home page to save $30 on a $200 order made it $170. Amain has a code u can use to have it shipped for like $187.
Werks for sure!!
GO-Engines gx5r and be done with it.
