Clutch bell tricks?
Anyone have any tricks to remove a clutch bell that wont come off? mine will move freely but wont come off, im almost sure that my inner bearin went out. Witch could explain all of the built up metal around the fly wheel. Thanks Guys!:cool:
pry if off with a screw driver, or clamp it down on a vise and just give it a good yank. It shouldnt be that hard.
Originally Posted by Beenbreto
(Post 7550030)
How have you been lately in Germany? |
yeah i tried all of those things but no luck. Well i havnt put it in a vise yet becasue i dont have one of those in my room lol. But ill take it to work tomorrow.
Chris, Germany is cool so far. just working and somewhat training. Hows the track doing? cant wait to get back. Should be back in mid AUG So ill be there to put some laps down with you and hopefully i can get my second roller up so we can go head to head on the truggys. lol My old man tells me that there is a good show up on wensday nights good stuff. Are you still doing the JBRL? |
Spray
Spray some wd40 on it and let it sit, then try. Sometimes it gets a bit rusty. I usually put a dab of grease on the crank so it won't get stuck on there.
(Post 7550138)
Originally Posted by merdith6
(Post 7550173)
+1 on too long! i check mine after each race day. inspect shoes, springs, bearings, etc.
just have to get after it with a screwdriver and pry it off. if you can get a screwdrivwer under each side that may help. good luck |
clutch bell rubbing
So i have a custom integy 49t spur gear which is rubbing against my 15t high performance clutch bell on my HPI Savage. I tried moving the engine mount back a bit so that doesn't happen. I have moved it back as far as i can. It's not a stock engine, Axial 0.28. Anyone know any other solutions ? I tried adding an extra washer to the spur gear / cb to make sure it's tighter. This doesn't work as the cb will always move when it's at idle. Any other solutions ?
Originally Posted by dmakrc
(Post 7550654)
on another note a buddy of mine had a clutch bell get stuck on him a couple of weeks ago, hit it with a head gun get it good and hot, i mean hot and it should come right off. |
Originally Posted by carlam
(Post 7550846)
-1 for hijacking lol:lol:
Tricks for Clutch bell
When in doubt-replace the bearings When in doubt-replace the clutchbell Their are you tricks ;) No seriously-that is how i was taught |
No
Originally Posted by dreaux
(Post 7550449)
wow. you must let yours sit a long time. I am taking mine off every time i run my car it seems.
Loctite tends to work its way in between the inner race of the bearing and the crank itself and basically LOCKING the bearing in place.
2 Flat head screw driver's on either side of the bell will Easily remove a stuck bell or at least get it up off the flywheel enough to get a good grip on it. Grease on the crank shaft is IMO not a wise idea. |
Hmm
Originally Posted by Integra
(Post 7551871)
2 Flat head screw driver's on either side of the bell will Easily remove a stuck bell or at least get it up off the flywheel enough to get a good grip on it. Grease on the crank shaft is IMO not a wise idea. I don't use locktight. I just grab the flywheel with some pliers, gently, and turn the 2.5mm head on the 3mm screw tighter than just holding the flywheel by hand, works every time. You can also use those cap head washers for a precise fit and longer bearing life. http://www.amainhobbies.com/product_...-Washer-Blue-6 |
