clutch setup on losi 8ight
hi there i went racing last night and i have now got my car dialled (just needs a few tweaks here and there) in thanks to the help of stanton. the only problem is the start of a race. my car seems to be sluggish of the line. it has to rev high and it doesn't have as quick of a start as other losi 8ights up at my track. and im pretty sure it is the clutch setup.
i am using the team losi aluminium long life clutch shoes with gold springs all round. should i get some silver clutch springs? should i have two gold and two silver? what spring setup do you recommend?
many thanks
lewis
many thanks
lewis
also has anyone got a spring guide (tells thickness and angle of springs)?
many thanks
lewis
lewis
It sounds like either the clutch is worn and needs new shoes or the springs are too stif. Take the measurement across the clutch and if it's 23.4 mm or less you need new clutch shoes. But with the springs. Try 2 green and 2 gold. 4 gold will wear out the shows faster. Actually run 2 blk and 2 green that's where I like it at. My car felt too much lie a rubber band when it would take off with green and gold. Try the springs but I the shoes are shot it doesn't matter what you do the problem will still be there.
thanks i think the springs are just to stiff, i will look at my clutch and see what the shoes are like. so frank you recommend black and green? i will try it but it is just trial and error really.
anyone recommend a good spring setup?
many thanks
lewis
many thanks
lewis
A lot depend. On the engine you are running too. I run black and green In the buggy because I didn't like the way the green and gold felt with a speed engine. With another engine the green and gold are perfect. But you are correct it is personal to each driver and it's all trial and error. Now the truggy is just fine with the same engine and green and gold.
thanks for all the comments i will buy all the springs so that i can try different spring setups. the only problem is having to take the engine out every time (annoying).
i will try gold and green and if i dont like it i will try black and green. it will be a slow progress.
many thanks
lewis
many thanks
lewis
Just to be sure, buy new clutch shoes. How much gas was on the old shoes?
what do you mean? the engine has had about a gallon through it and them shoes have been on there since the engine was new. i was going to get two carbon shoes and some green springs and have the other two shoes the used losi long life shoes with gold springs. but is it ok to have two new carbon shoes and keep two used long life shoes?
ok cheers for the help i will order some tonight and report back
many thanks
lewis
many thanks
lewis
