Losi Clutch Bell Bearing problems.
I'm going through them like water. 3 qualifers and a 20 minute main and their toast. I have the right amount of CB play. What I take them off after the mains I have way more CB play then when I started. The bearing still spin. I replace the bearing and the extra play is gone.
I assume the extra play is from the bearings going bad?
What could be causing this in such a short amount of time?
About to ditch the losi set up and run an M2C set up, btw these are the TKO specail best cb bearing.
have you tried a new c bell.. sometimes the bell can get slop and cause the bearings to go out prematurely
[QUOTE=l3asher;5310057]Looked at the mesh and its at a 90 degree angle. How do you tell if the gear mesh is too tight?
The Losi Mesh is unlike any other buggy/truggy. Put you finger on the center gear and hold it tight the you should be able to rock the clutch bell back and forth. You would think it's too loose, but thats just right. If the teeth do not click back and forth then it is too tight.
Hope I explained it well enough.
You do NOT use the paper method with the 8ight's That is too tight.
I too experienced tons of clutchbell bearing failures on my 8ights last year. I was already setting my mesh a tad looser than on other vehicles and it was still happening. I wasn't even getting a 5 minute qualifier out of a set of Avids.
Then I read about all the flex at the engine mount area and where people suggested using a one piece engine mount. Once I added those mounts the bearing issues were a thing of the past.......
I would grab one of these if I were you:
http://carolinasrc.com/Webstore/Scri...idproduct=5161
Make sure that your motor is sitting perfectly straight. That's why they etched the chassis on the 2.0 to help assist with motor alignment.
I dont have such a problem but i used to change the bearings every 4 Litres of running.
I going to try and run a looser gear mesh and see, I have been using the paper trick.
Try using the ceramic bearing.
in extreme cases, clutch shoes can mushroom to the point that they rub on the bearing (because losi uses an oversized bearing). might take a look at that. took me a few rebuilds to figure it out.
I've heard all of the above advice before, escpecially the ones pointed right at the Losi and loose mesh and chassis flex. The ONLY thing I can think to help you that you need to answer is if you have ever had "good luck" with bearings in that car and how you started with it pertaining to the engine.
Like new engine, new car, no problems at first - now problems. Info like that. Because if it's nothing else check your engine bearings. If they are getting older no matter what kind of engine (past the 1-3 gallon mark) they can have enough slop to blow out CB bearings even as quickly as two tanks. If you continue to chase this for awhile it may become more and more often than you are experiencing now. Hope you find the problem soon!
Becuase if it IS an engine bearing and you don't figure it out soon you may blow an engine bearing up!
Give the guy a call that was going to help you over the phone
