Engine bearing question
Sometimes you have to put a shim between the bearing and flywheel to keep the flywheel from hitting.
Be sure the main bearing is placed in the right way, from the rear you must see the ball ckearly and not the ring holding the balls.
If that is right then 1 of the bearings needs to be pushed further.
