changing ninja engine bearings
you will need a oven, oven mits, your empty crank case (cleaned with nitro spray or brake cleaner), a rubber mallet or wooden dowel, crank and flywheel.
preheat your oven to 300 degrees. Make sure everything is out of the crancase except your bearings. once it preheats to 300 degrees, place it in the oven for 10 minutes.
when you take it out (will be hot as hell) get a nutdriver or anything bigger then the inner diameter of the front bearing and tap it out. Now tap the back of the crankcase on the edge of the counter (with the exhaust hole hanging of the edge) and rear bearing should fall out.
now get your front bearing and press it in to get started and take a ruber mallet (or wooden dowl) and tap it all around until it is seated.
now take the rear bearing and put it on your crankshaft and install the crank. Take the flywheel and put it on the end of the crank, tighten the flywheel to seat the rear bearing like normal and your done!!
Might have to heat it back up during the process if it takes to long to complete all the steps.
