losi eight t steering??
i have a losi eight t truggy it turns right very well but not so well left, i have a airtronics servo, and trim is 0 when servo horn was installed, any ideas why it turn right better than left?? the tires seem to turn both ways all the way, is there somthing im missing?? any help would be great, thanks
I would disconnect the servo from the servo saver and see if it functions properly without being connect to anything. Also, make sure your batteries are good. I had the same problem that was simply fixed by recharging my batteries.
hows your transmitter set up..?? end points, sub-trim, steering trim, dual rate...??).
