vspec case question >
vspec case question
vspec case question
Old 04-15-2010, 09:17 AM
Trader Rating: 155 (99%+)
Default vspec case question
what does the little washer do that goes in the carb neck that the carb rests on? i am changing carbs on my vspec and running a ninja carb.. so my question is do i still need to run that washer in the because the speed/ninja cases dont use it. so is it something that is specific to the vspec carb or the vspec case
skoalisbad4me is offline
Old 04-15-2010, 09:50 AM
Are you talking about the rubber o-ring, If it is then yes you will need it, the vspec have a groove in there and thats were the oring sit
Shuming is offline
Old 04-15-2010, 09:56 AM
no not the rubber oring. the metal washer tat goes under the carb. this is what im talking about
http://www.amainhobbies.com/product_...21-VZ-B-V-Spec
do you need this if im not running the vspec carb? all it looks like it does is ust give the carb something to sit on instead of just being in there. doesnt really seem necessary
Old 04-15-2010, 10:10 AM
IDK, I have 3 vspecs and dont recall seeing that, but if its there I would use it
Shuming is offline
Old 04-15-2010, 11:13 AM
2tap's Avatar
I have a older speed that has that washer. I assume it's there for a reason.
2tap is offline
Old 04-15-2010, 11:51 AM
i kinda assume it is there for a reason too i just dont know what that reason is and if the motor would run the same without it. looking inside the case with it there and without it just doesnt seem like it serves a purpose except giving the carb something to rest on
Old 04-15-2010, 12:02 PM
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I would leave it in. I don't think it would hurt running without it, but it's not a bad idea to leave it in there. Btw my Speeds have come with them in there too. I would think it's more based on the case it's in than the carb(as the carbs are identical) so I would leave it in there.
JAMMINKRAZY is offline
