clutch breaking springs
my clutch had a hanging shoe twice today (dynamite max life, 1.0 springs). and each time the clutch spring had broke on the part that sits in the groove on the flywheel nut. i replaced the spring and it happened again. At the end of the day i was breaking down the clutch to clean the engine and i noticed the shoes were not sitting on the flywheel properly and the shoes were a bit loose on the flywheel. the shoes have a few gallons on them (they do last forever), but they still have a couple gallons left. I think the bottom of the shoe where it spaces it of the flywheel is worn off. It is literally sitting flat on the flywheel.
I could replace the shoes and flywheel, but i don't see a reason for it unless i have too. the pins on the flywheel look a little worn but not near as much as some other flywheels i have.
anyone know what's going on?
well i have had this car for almost 2 years and have never had this happen. besides, what spring would you suggest? i have tried racers edge springs, but those springs are wwaaayyy to tight.
btw, i was putting on my flywheel last night and my lug wrench striped out. I had a deep socket and i tried to get on the flywheel nut and it didn't fit inside the pins very well and it might have bent them, but i can't tell.
Do your springs stick out of the clutch shoes when they are on the flywheel? Could it possibly be your clutch bell
2. possibly. The clutch is pretty old (racers edge vented tri nitrate). It's possible that the shoes have worn out the clutch bell to the point where the shoes have to go out further and stressing the springs. But the clutch bell would have to be worn to just about nothing. And i have never even heard of that happening.
yeah, just checked before you suggested it. yup. 2 big grooves. There is a rail in the middle.
but why would that break my spings?
you can use the kyosho clutch springs on mugen. they work great and is what i was using last year when the mugen ones were breaking
