d8 bearing
so i am planning on purchasing a new d8 and i am wondering what bearings i should put in it i am currently debating between ACER and ready rollers any suggestions?
I ran the kit bearings then replaced them with AVIDS.
Originally Posted by Alan D.
(Post 7124237)
Answer-RC! Check out http://www.twisted-rc.com/bearings_11.html for a complete bearing set for your D8 at a great price!
Avid is all I use, you cant beat the price and shipping is really fast. David is a great guy and racer, so he knows what works!!
http://www.avidrc.com/ Tim |
kit
run the kit bearings till they need replaced then run avid
avidrc.com |
Originally Posted by wfo
(Post 7124323)
AVID......
i herd those wear out pretty quick?
Avid bearing , great product. Try them, 1.00 each cant go to wrong.
yeah i most likely will
yeah do like bcarter007 said, run the kit bearings for now, order the Avid ones and when you rebuild the diffs and stuff, just replace the bearings then. I ran the kit bearings for a while on my first D8 and they were fine. Just make sure when you order the Avid ones, get the ones with black rubber seals. Also be a good idea to order several sets of clutch bearings to keep on hand since they wear out fast anyway, no matter what brand.
Tim |
thanks will do:spidey:
You should seriously consider the Answer RC-USA bearings. Excellent bearings at a great price...you can't ask for anything more! As the others have said, run the kit bearings until you begin to do your maintenance, then replace as necessary. I've been using the kit ones for quite awhile with no failures.
