losi brake disc set >
losi brake disc set
losi brake disc set
Old 03-05-2010, 10:33 AM
alexrckid's Avatar
Default losi brake disc set
picked up new losi brake discs for my 8T-2.0.....
http://www.amainhobbies.com/product_...Set-20-Updated
problem is that the NEW discs are of a slightly smaller diameter than the stockers.................even though the product discription sez that they're for both the buggy and truggy i'm kinda wondering.......??
alexrckid is offline
Old 03-05-2010, 10:51 AM
losi_racer's Avatar
Trader Rating: 25 (100%+)
what are you wondering?
yes, they work for both buggy and truggy. its more cosistent, no fade, no maintenance. they are great. i dont see your issue?
losi_racer is offline
Old 03-05-2010, 11:25 AM
tc5 man's Avatar
i was thinking about get these disc brakes, do you have to loosen the brake screws since there smaller in diameter?
tc5 man is offline
Old 03-05-2010, 11:27 AM
MontanaMaxx's Avatar
so are these better than the heavy duty vented ones?
MontanaMaxx is offline
Old 03-05-2010, 11:30 AM
l3asher's Avatar
The disc are thicker so you have to loosen the screws a little.
Yes they are.
l3asher is offline
Old 03-05-2010, 11:42 AM
tc5 man's Avatar
Yes they are.
ok do i have to get the 2.0 brake calipers? i notice the part, number is diffrent than the, 1.0 brake calipers? and im using the 1.0 center mounts also. so you just loosen, them a little intill they move free?
tc5 man is offline
Old 03-05-2010, 11:44 AM
cornerspeed's Avatar
There needs to be a .5mm clearance between the pads and rotors.
cornerspeed is offline
Old 03-05-2010, 11:45 AM
BAUSTIN's Avatar
the 2.0 pads are twice as thick and dont bend and allow fading, i have saw people use two 1.0 pads back to back for a toatal of four pads......yes lossen the screw until the diff turns free.........
BAUSTIN is offline
Old 03-05-2010, 11:46 AM
losi_racer's Avatar
i have a 1.0 c/d assembly still from my old cars and i went to test them and they worked, just had to loosen the screws
Old 03-05-2010, 11:48 AM
tc5 man's Avatar
ok cool so you just loosen the screws, a little intill the brake disc move freely?
im guilty of dont paying, attention to my brake disc lol.
tc5 man is offline
Old 03-05-2010, 11:50 AM
BAUSTIN's Avatar
that could make your car drive a little funny and act weird in the air.......jump nose down more than likely.......
BAUSTIN is offline
Old 03-05-2010, 11:55 AM
That is the way they are made, both disc are the same size. It is not a problem, they work very well.
tc5 man's Avatar
if you loosen where, the disc move freeley? i know i just followed the instrutions and set the, brake clearance there. i actually dont, use brake in air most of time by buggy, jumps level somewhat. on the ground i use them though. now i gone to run truggy so i might, have to use brake more in the air.
tc5 man is offline
Old 03-05-2010, 11:56 AM
They will work on your 1.0 stuff. The 2.0 pads and center diff mount are actually better though. The pads are thicker, they don't flex.
Old 03-05-2010, 12:02 PM
tc5 man's Avatar
i might get the 2.0 center mount and, brake pads and disc than so i guess i can still use, the 1.0 linkage too. than and the 1.0 radio tray?
tc5 man is offline
